6.0l glow plug issues
Old Sep 13, 2023 | 09:06 AM
Jokester00's Avatar
Jokester00
Originally Posted by Maxium4x4
At least we are getting somewhere.....
Not with cheap parts, we're not... 🤣
-jokester
Old Sep 13, 2023 | 09:07 AM
runthatjunk's Avatar
runthatjunk
So does the mushroomed head on the glow plug mean it has opened the circuit? Guessing that's why wasn't getting a reading?
Old Sep 13, 2023 | 09:10 AM
bismic's Avatar
bismic
Also - I'm betting the heads weren't "mushroomed" going in, so ...........................................
Old Sep 13, 2023 | 11:58 AM
Thebelter's Avatar
Thebelter
4wd Low
Thanks for all the thoughts and info everyone.
yes the plugs get no ohm reading after removing them and testing directly on the plug out of the engine. They were certainly not mushroomed the one day before when i put them in. Luckily all except one came out easily. The one I thought was stuck took a lot of messing with and eventually I got it but it took a lot of pulling with vice grips. What's even worse is I did this at work at midnight so no chance of running to get better parts.... so I had to put in another one of these new pieces of ***** that i still had into each cylinder. Immediately had the same code after replacing so they must have immediately mushroomed. The level of absolute garbage of these glow plugs is insane. 4 years ago when I bought these i paid 36 bucks for 8 plugs and both harnesses on ebay. I don't know what I was thinking lol 😆 😅 😂 lesson learned.
Old Sep 13, 2023 | 12:03 PM
Jokester00's Avatar
Jokester00
At least you DID learn your lesson.
Sometimes OEM parts aren't cheap. GOOD aftermarket parts aren't cheap. However, when you compare the initial cost to your time and effort that you spend RE-DOING the job because of the $$ you tried to save by going the cheap route (Amazon, E-bay, Cooter's One-Stop Grub Hub/Gas Station/Injectors, etc.), you end up the loser in the long run!
Buy once - cry once, as they say!
-jokester
Old Sep 13, 2023 | 12:10 PM
Thebelter's Avatar
Thebelter
4wd Low
-jokester
you are absolutely right. I never thought something as simple as a heating element could be made so poor but I was wrong.
Thebelter
Sep 12, 2023 03:28 PM
LSO1123
Jan 28, 2018 11:16 AM
the_auto_tech
Aug 21, 2013 08:45 AM
jayc3169
Oct 26, 2011 05:16 PM
Greenlawnracing
Mar 11, 2007 06:02 PM
