motor mounts
Old Nov 20, 2003 | 06:15 PM
guillermorivera's Avatar
guillermorivera
Question motor mounts
When I drive off from a stand still (truck already in drive), I feel a thump as if there was a shift with somthing heavy, it seems to come from the engine area but not under very soft acceleration. My u-joints don't clunk when I put it into gear. Could it be my motor mounts, and if so, how do I diagnose it and if need be, how do I go about replacing them myself?? Thanks for the anticipated responses??
1994 f-150, 4x4 extended cab automatic, eod, 95k mi.
Old Nov 20, 2003 | 06:47 PM
TheWiz427's Avatar
TheWiz427
Try this just be careful! With the hood open so you can see the engine from the cab hold your foot on the brake put it in drive and slowly give it gas. As you load it if the mount is broken you will see the engine lift to the right(you can do this in reverse to check the other mount as well).
BTW if you have a friend that can watch for you its easier.
Old Nov 21, 2003 | 12:07 AM
clutch's Avatar
clutch
My truck did the same thing and I couldn't figure it out till I swapped the motor and found that the bolts were loose that held the motor mount brackets to the frame. The actual rubber mounts were fine. Check this out first as the bolts are pretty easy to change.
Old Nov 21, 2003 | 08:44 AM
guillermorivera
Thanks guys, I'll try these things this weekend. In the event I have to replace one, how hard is it and what's involved??
Old Nov 21, 2003 | 09:01 AM
guillermorivera
DISREGARD MY LAST POST, I STILL HAVE THE ALLEGED MOTOR MOUNT PROBLEM
Old Nov 23, 2003 | 04:43 PM
f100guy's Avatar
f100guy
not too hard just jack the motor up from the oil pan after loosening the bolts and nuts from the motor and frame and slip the new ones in place and torque them down. that is all
Old Nov 24, 2003 | 07:38 AM
guillermorivera
The Wiz 427, I tried the test you suggested and the engine tilts in both directions with the truck in drive and reverse respectively. How much tilt is normal??
Old Nov 24, 2003 | 07:39 AM
guillermorivera
Thanks for the info F-100 guy
Old Nov 24, 2003 | 11:42 AM
guillermorivera
BTW, f-100 guy, is the oil pan strong enough to undure the weight of the engine, also, does the trans mount have to be un-bolted to lift the engine?
Old Nov 24, 2003 | 01:28 PM
f100guy's Avatar
f100guy
the oil pan is plenty strong to lift the motor with. you may also want to loosen the tranny mount nuts a bit to be safe.
Old Nov 24, 2003 | 06:25 PM
71swissaqua's Avatar
71swissaqua
I would at least slip a piece of plywood on top the jack. The engine is going to torque some even if the mounts and bolts are good. If the mount is bad it'll lift up and clunk back down when you let off the gas.
Clint
Old Nov 25, 2003 | 03:49 PM
guillermorivera
Update, I had the rear springs replaced yesterday and my drive shaft balanced + new u-joints. As part of replacing the springs, one of the shackle bushings was replaced. So far, i don't feel the thump. Maybe it was the shackle bushing or the u-joint?? Whats do you all think?
Old Nov 25, 2003 | 04:36 PM
f100guy's Avatar
f100guy
well if it makes now thump then it is fixed. my 5.0 tbird needs the forward motor mount the fan rubs the shroud if i punch it at a light
Bubba Jones
1978 - 1996 Big Bronco
May 20, 2013 08:15 PM
jb65542
Feb 27, 2011 08:43 PM
benmoderow
Dec 3, 2009 06:15 PM
cworley250sd
Oct 9, 2007 07:48 AM
moparnut
Mar 24, 2005 06:16 PM
