390 in a 75 ford
Old Feb 27, 2011 | 07:38 AM
jb65542's Avatar
jb65542
390 in a 75 ford
i have a 390 not sure what its out of but it has differnet motor mounts, i think it is a 65 or older because it only has two holes for the mount, do they make a mount for this motor in my truck, or any suggestions on how to make it work
Old Feb 27, 2011 | 02:59 PM
jchamp429's Avatar
jchamp429
I don't know anything about the mounts, sorry. As far as what the engine is out of, if you post the casting numbers from the block, heads, and/or intake and we can tell you what they mean and what they are out of.
Old Feb 27, 2011 | 06:52 PM
jb65542's Avatar
jb65542
where do i find the number on the block at, the nubers on the heads are c4ae 0900 or 0060 not sure which
Old Feb 27, 2011 | 07:05 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
2 bolts mounts are the early type, and 3 bolt style are the later type. I think 66/67 was the switching point.
Old Feb 27, 2011 | 07:17 PM
jb65542's Avatar
jb65542
Is there a way to put this engine into a 75 ford truck
Old Feb 27, 2011 | 08:43 PM
keisha9's Avatar
keisha9
my friend who has a 75 also bought a 2 bolt block rebuilt and didnt realize it was different than the Truck 4 bolt mount.I suggested making a metal plate to offset the difference between the two mounts. basically he bolted the mount to the plate and the plate to the block its not much maybe an inch maybe inch and half. anyways he used a peice of metal and made it work......pretty easy however the block will sit higher by the thickness of the metal you use
Visalia65
19
Jul 5, 2009 11:03 PM
jav409
Mar 8, 2008 01:46 AM
AZFairlane
Oct 22, 2007 09:11 AM
poorfolks
Engine Swaps
Aug 17, 2004 10:31 AM
poorfolks
Aug 16, 2004 09:25 PM
