Reverse / Backup Wiring Help
Old Sep 11, 2023 | 01:53 PM
4x4Lightning96's Avatar
4x4Lightning96
4th Gear
Exclamation Reverse / Backup Wiring Help
I have a 2017 F-550 6.8l gas service truck. My boss bought me a new backup camera to install and I need help finding a place to wire in the trigger wire for the camera to activate when put in reverse. I need a wire color & location, alternate location / way to tap into what I need to make it work. I was told I could just run wires all the way to the reverse lights but I'd rather not do that.
Old Sep 11, 2023 | 02:26 PM
Buckeye-SD's Avatar
Buckeye-SD
If the 550 is like the 250/350, there's a 20 pin connector on the passenger side frame rail next to the spare tire. All of the rear lights pass through it. For my 2022, the GN-BN (Green Wire with Brown stripe) is the reverse light wire on pin 7. I would assume it was the same for 2017. You might want to check with a volt meter or test light.
Old Nov 6, 2024 | 11:07 AM
Ssmitty73's Avatar
Ssmitty73
1st Gear
Reverse back up light
Hello,
Got a 2017 F250 that both reverse lights are not working. Cleaned the connectors with electrical cleaner and then it works for a day or so then they go out again. Do you think it's the connector or gear selector switch on the tranny? Also, are the plugs/connectors replaceable?
Thanks for any help!
4x4Lightning96
Large Truck
Oct 9, 2023 03:14 PM
superJEP
Apr 4, 2022 02:18 PM
pspc271
Jun 29, 2018 02:44 PM
buening
2004 - 2008 F150
Oct 5, 2014 10:39 AM
SGTSIXER
1997 - 2003 F150
Sep 29, 2012 03:23 PM
