Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Reverse / Backup Wiring Help
Old Sep 11, 2023 | 02:13 PM
4x4Lightning96's Avatar
4x4Lightning96
4th Gear
Exclamation Reverse / Backup Wiring Help
I have a 2017 F-550 6.8l gas service truck. My boss bought me a new backup camera to install and I need help finding a place to wire in the trigger wire for the camera to activate when put in reverse. I need a wire color & location, alternate location / way to tap into what I need to make it work. I was told I could just run wires all the way to the reverse lights but I'd rather not do that.
Old Oct 4, 2023 | 02:34 PM
1TonBasecamp's Avatar
1TonBasecamp
Back to the top.
Don’t really have an answer, but maybe the suggestion for going back to the lights, or at least part of the way back to the lights was because sometimes the range switch (or whatever they call it these days) on the transmission has a boatload of wires bundled together, and would be trouble to separate and splice into.
Maybe even check out your fuse box under the hood or under the dash to see if there’s a dedicated back up light fuse.
There probably is, but now that I think about it it’s probably got power anytime the ignition switch is on. Not necessarily fused between the transmission and back-up lamps.
good luck. Back up cameras are great!
Old Oct 9, 2023 | 03:14 PM
big job's Avatar
big job
splice the trigger wire to the light done..
4x4Lightning96
Nov 6, 2024 11:07 AM
skl
Mar 26, 2014 12:13 AM
pminne
Feb 25, 2010 07:53 AM
72Blazerod
Apr 30, 2008 08:33 AM
TNT in Round Rock
Jul 2, 2006 06:35 PM
