Bent push rod?
Old Aug 10, 2006 | 02:52 PM
Clint Knotts's Avatar
Clint Knotts
Bent push rod?
2000 F-350 sounds like it could have a bent push rod,it seems to run good and smooth, if it was a gas engine that would be the first thing I would check.
It also seems to be alittle under powered,do these engines have a history of bent push rods or broken rocker arm sattles?
Old Aug 10, 2006 | 03:00 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Since I have been reading most of the threads on nearly a daily basis I have seen one post of broken rocker arms. Not much help am I?
Old Aug 10, 2006 | 03:28 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
that post markadeck talked about was the one where a guy had a backfiring sound out of the intake. the case was that the exhaust valve was not working properly due to a push rod or rocker post damage, and it was pusing the exhausted gasses out of the intake valve and back into the intake with a loud pop. do you have any abnormal noises such as that? ALL of the info you could give about abnormalties will be the best help.
Old Aug 10, 2006 | 04:50 PM
Clint Knotts
There is no backfiring,just a noise like a lifter tapping,or a loose rocker arm.
Red454sedgwick
Feb 3, 2015 11:59 PM
rickatic
Oct 28, 2009 06:42 PM
bigbadwolfe
Dec 14, 2006 10:41 PM
grandjunktion
Nov 29, 2004 02:52 PM
big block power
Jul 12, 2002 12:34 AM
