EBS picture
Old Sep 9, 2023 | 10:05 AM
StanleyZ's Avatar
StanleyZ
EBS picture
Well crap, I intended to start a new post and messed up and posted as a reply to my post below. In my defense I am 2 weeks younger than the president. I have for a year and a half been trying to find the source of my intermittant over boost problem. Today I did a visual inspection of the EBP sensor which if I read it correctly could be sending bad signals to the truck and causing an overboost. Attached is a picture laying on my back under the truck. You can see the tube clearly and there is a gap of 1/16 inch or more between the tube nut and the down pipe. DOES THAT LOOK LOOSE TO YOU? BTW, I had a local shop replace my exhaust manifolds a moth or two before this problem began. I'm thinking maybe a tech forgot to tighten the EBP tube.
Old Sep 10, 2023 | 06:29 PM
FishOnOne's Avatar
FishOnOne
Looks possibly loose. Also what's the silver piece with exposed threads at the upper center of your picture?
Old Sep 10, 2023 | 07:30 PM
StanleyZ's Avatar
StanleyZ
Hmmm, I don't know what that exposed bolt is. I'll see it I can figure it out. The other item was not loose. I was able to rig a crows foot a ratchet and a short cheater bar together and try to tighten it. It was TIGHT and just to be sure I loosened it a bit, It turned freely so I secured it and called it a day.
GGALLIN1776
Mar 31, 2022 07:52 PM
Gmaan03
23
Jul 10, 2017 12:02 AM
tjmike
May 31, 2015 10:38 AM
agg_bagg
20
Aug 3, 2009 04:09 PM
nissandoc
Mar 26, 2008 07:40 AM
