2022 Ford Maverick LED Backup Reverse Lights - Super Bright Error Free No Flickering
Concerned about the dim factory backup lights on your 2022 Ford Maverick? Don't worry, Lasfit T-WT21W LED bulbs can provide you with bright white light at 6000K, ensuring that pedestrians and vehicles behind you notice when you're reversing.
These bulbs, with 15W and 1600LM per bulb, offer remarkable brightness for your 2022 Maverick. With a built-in MINI fuse and intelligent temperature control system, they also have a longer lifespan.
Installation is a breeze with the non-polarity design and similar size that allows for easy insertion into the existing housing. However, to eliminate any installation confusion, we are happy to provide an installation guide specifically for the 2022 Maverick.
Upgrade your backup lights and improve visibility during reverse driving with Lasfit T-WT21W LED bulbs.
The Installation Steps:
Step1:Use the screwdriver to remove the front and the bottom screws
Step2:Along the gap take off the taillight housing
Step3:Rotate the bottom of the factory bulb and take it off the front of the connector
Step4:Insert the LED bulb into the connector
Step 5:Rotate the bottom of the bulb and lock it in place.
Step6:Put the taillight housing back
Step7: Use the screwdriver tighten the taillight housing(remember 2 screws)
The T-WT21W LED bulbs VS factory halogen bulbs
If you have any questions about the installation steps or the T-WT21W LED backup lights, feel free to leave a comment in this post. We value your feedback and are eager to assist you in any way we can.
You can get more information about T-WT21W LED bulbs from this page: http://www.lasfit.com/products/wt21w...-reverse-light
LeoJr
01-14-2017 08:25 AM
