DTC P0232 help
Old Sep 5, 2023 | 10:43 AM
MDHunter's Avatar
MDHunter
DTC P0232 help
Using FOR SCAN, keep getting DTC P0232, High voltage fuel pump secondary circuit.
Truck runs fine, replaced the fuel pump and FP relay about 9 months ago.... Any ideas?
Thanks
Mike
Old Sep 5, 2023 | 11:47 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Are you getting P0203 as the title says or P0232 as you indicate in the body of the text?
Most likely it is P0232, so below and attached is some information and the pinpoint test.
See attachment for pinpoint test.
File Type: pdf
Bing03
Oct 18, 2017 03:29 PM
themicro
Aug 8, 2012 07:39 PM
vance
Jul 27, 2009 08:53 AM
jemini
Jan 4, 2008 03:06 PM
chucknc
Aerostar
Feb 8, 2004 03:17 PM
