E4od compatibility question
Old Sep 4, 2023 | 08:16 AM
Bllslggr's Avatar
Bllslggr
I have a 97 7.3 4x4 and am likely in need of a tranny swap or rebuild. Would an e4od from 95 bronco 4x4 be direct fit or easily adapted ? Possibly can get low mileage for good price. Thanks.
Old Sep 4, 2023 | 08:47 AM
farmert's Avatar
farmert
The bronco tranny will not bolt up to your diesel, as it has a different bolt pattern. You will need a tranny from another 95-97 diesel 7.3 truck.
Old Sep 4, 2023 | 08:54 AM
Bllslggr's Avatar
Bllslggr
Ok. I assume bell housing is different. Likely internals are different ratio too anyways. Thanks for quick reply.
Old Sep 4, 2023 | 09:33 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
All E4ODs had the same ratios. The cases are different to bolt to different engines.
coreyallan01
Jun 1, 2022 07:51 PM
Trickedout420
Apr 6, 2007 08:15 AM
