E4OD compatibility
Old Jun 1, 2022 | 09:24 AM
coreyallan01's Avatar
coreyallan01
E4OD compatibility
Morning Fellas, I have a quick question about E4od interchange. A guy fairly close to me is selling a 4x4 E4OD out of a 1993 IDI truck. I have been looking for a trans to build for my 97 460 4x4 E4od truck. Would anyone know if their physically the same? Could the 93 trans be built and bolted up with my existing xfer case? Thanks guys.
Old Jun 1, 2022 | 09:41 AM
OhioFordFarm's Avatar
OhioFordFarm
No. bell housing bolt pattern is different for the IDI Vs the big block 460. The transfer case would bolt up to the trans, but the trans will not bolt up to the motor.
Old Jun 1, 2022 | 09:57 AM
coreyallan01
thanks for the definitive answer! Appreciate that.
Old Jun 1, 2022 | 04:04 PM
Encho's Avatar
Encho
The Southernmost Mod
I think the internal are also of a different setup for the diesel, which won't work well with ant of the gas engines. I think I've read this some time back.
Old Jun 1, 2022 | 06:39 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The internals will work fine with the gas engines, but as noted above the diesel trans won't bolt to the gas engine.
Old Jun 1, 2022 | 07:51 PM
kevinv10's Avatar
kevinv10
While I have nothing to add, it brings up a question of, does anyone make an adapter plate for the diesel transmission to gas motor? Or would the added thickness not be a viable option? Just curious.
flaboy1979
Dec 22, 2013 06:38 PM
Dstosh
New York Chapter
Mar 6, 2009 08:20 PM
78f3504x4
Jun 20, 2008 09:45 AM
warren1994
Jul 21, 2005 12:57 AM
