Adjust altenator charging set point
Old Sep 3, 2023 | 11:09 AM
TonyTeo's Avatar
TonyTeo
4wd High
Just replaced my alternator, and previously replace my battery with an AGM style one. Specs for the AGM battery requires approx. 14.7 volts to properly charge the battery to full charge state, but then needs to be reduced to 13.8 for float. Is it possible to program the ECU to monitor the charge state of the battery, and adjust the voltage as necessary. IE: To act as a smart charger.
Old Sep 5, 2023 | 10:35 AM
torq'ta 5 8's Avatar
torq'ta 5 8
the voltage regulator, in alternator, already does this, your trying to beat a dead horse
Old Sep 6, 2023 | 08:33 AM
TonyTeo's Avatar
TonyTeo
4wd High
Yes they charge to 14.7 volts, but don't provide a float voltage. The ECU would be responsible to perform that service. I just don't know if it can be programmed to do so.
Cheers,
TT
Old Sep 6, 2023 | 09:41 AM
Don Ridley's Avatar
Don Ridley
There is no information on the Forscan sites that show your model year F150 has settings for the battery type. Newer (2015+) trucks have this setting. Your ECU was probably not designed for the option of AGM batteries.
Old Sep 6, 2023 | 04:21 PM
TonyTeo's Avatar
TonyTeo
4wd High
Thanks for the feedback. It's nice to correspond with some0ne that has a clue.
Old Sep 6, 2023 | 06:24 PM
torq'ta 5 8
which you still dont, heard of google, common sense tells you--> define voltage regulator-- 14.3-14.4v for the first 10-20 minutes of driving (on the first start of the day)
Then it varies from 13.5 to 14.0v throughout the rest of the day, and the load on battery. Our 20 year old alternator doesn't care that you put AGM in it, they're not that spiffy.
Old Sep 7, 2023 | 07:40 AM
TonyTeo's Avatar
TonyTeo
4wd High
Hi,
Have you verified that operation. I assume you also own a 2005 F150. If you found that info on Google or YouTube, can you please post a link.
Thanks,
TT
Old Sep 7, 2023 | 08:34 AM
jr105's Avatar
jr105
I had a 98 Corvette that had the battery mounted above the computer so if it leaked, acid would drip on the computer and wiring. It was a common thing in these to replace the battery with an AGM. I did that and it behaved exactly like in the above quote. The car had a voltmeter so I could see the voltage as it ran. The 4 year old AGM was still working fine when I sold it. I'm pretty sure all these regulated alternators worked the same in that generation of cars.
Old Sep 9, 2023 | 11:18 AM
torq'ta 5 8
Mine is 04, here is link-->2005 Ford F150 has a repeat problem with battery discharge - Fixya
wagaskyc
19
Jan 15, 2023 05:18 PM
Deadsquiggles
1978 - 1996 Big Bronco
Jul 8, 2014 09:30 PM
waumpuscat
Aug 28, 2012 07:46 AM
2001SuperCrew4x4
1997 - 2003 F150
Aug 3, 2011 12:58 PM
Roger T. Pipe
Feb 28, 2010 01:41 AM
