1978 - 1996 Big Bronco
Alternator or battery?
Old Jul 3, 2014 | 06:06 PM
Deadsquiggles's Avatar
Deadsquiggles
Truck has started acting like it doesn't want to stay running. It starts but the volt meter is only around 1/4 way and it wiggles back and forth. Idle acts funny at the same time like it can't keep itself running. I'm guessing that's the alternator since if it was the battery, it wouldn't start at all?
Old Jul 3, 2014 | 09:28 PM
Fordman96's Avatar
Fordman96
Check your battery connections. I had an issue with mine like that, first it wouldn't start, then if it did it would charge weak or charge really high since my connections were corroded.
After your connections are solid, put a volt meter and check the alternator output or take it up to your local auto parts store and let them test it.
Old Jul 3, 2014 | 10:39 PM
Raleigh1's Avatar
Raleigh1
I would start by putting a meter on the alternator output and checking the voltage.
If you have ~14 volts at the alternator move to the battery and do the same. If you have ~14 volts as you should at the alternator but not at the battery you have a bad cable or connection. If you don't have ~14 volts at the alternator either the voltage regulator is bad or the alternator itself.
Old Jul 8, 2014 | 09:30 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
What I do is undo the hot post on the battery. If it automatically dies...it's the alternator.
danlee
Electrical Systems/Wiring
Apr 27, 2019 07:33 PM
Calheader
Nov 19, 2014 02:30 PM
donaldm
1983 - 2012 Ranger & B-Series
17
Jul 13, 2009 10:50 AM
r0n1n
Jun 27, 2009 08:53 AM
k150
1997 - 2003 F150
13
Feb 10, 2009 06:47 PM
