Alternator Output Too High?
Old Feb 27, 2010 | 11:42 PM
Roger T. Pipe's Avatar
Roger T. Pipe
Went outside to start my 96 F150, found the battery dead. Charged it up, started right up. Next morning, same thing...had the alternator bench tested at Advance Auto and its putting out 16volts. Does this warrant replacement? What would this have done to the battery? Thanks in advance!
Roger
Old Feb 27, 2010 | 11:49 PM
zxwut?'s Avatar
zxwut?
The alternator is supposed to be higher than battery voltage, but usually around 13.5 to 14.5ish volts so that the battery is charged. The voltage regulator is what maintains that voltage window. If it goes much higher than that, it can cook the battery. My guess is that your voltage regulator wasn't working properly which let the alternator's high output create too large of a current to the battery, which overcharged the battery and killed it.
Edit to add a second thought...
It could also be that the VR is working properly and it's not letting that flow of current to the battery because the alternator's output voltage is over what the VR is set to regulate it at, so it's just not charging. Either way, it's an alternator/VR problem.
Old Feb 28, 2010 | 01:41 AM
LCAM-01XA's Avatar
LCAM-01XA
The VR can interrupt power flow from the alt to the battery tho, as the charge cable stud comes out of the rectifier and not the VR.
Michael Rogers
2004 - 2008 F150
Jan 1, 2016 09:07 AM
Roger T. Pipe
Mar 5, 2015 06:21 PM
Roger T. Pipe
Jun 22, 2014 06:03 AM
99StrokeXLT
Apr 4, 2013 05:51 AM
Roger T. Pipe
Feb 5, 2012 09:54 AM
