Coil relocating idea
Old Sep 1, 2023 | 01:26 PM
Grampa69's Avatar
Grampa69
When searching, I saw owners/builders mention relocating their coil or coil packs.
I keep thinking about the location of the coil right in front of the distributor, near the carb and so close to the valve cover. I am tempted to move it to the firewall, near the distributor.
Has anyone else considered or done it? I would still mount it horizontal, just get it off the hot intake. I don't think the wire length would be a problem.
Anyone?
Old Sep 2, 2023 | 03:14 PM
f5fordgirl's Avatar
f5fordgirl
After I put a 272 in my 47, I mounted the coil to the firewall, between the dist cap and end of firewall, mounted it standing up, looks good to me.
Old Sep 15, 2023 | 11:24 PM
charliemccraney's Avatar
charliemccraney
You want all wire lengths to be as short as possible, As long as you can place it somewhere relatively close on the firewall, it will be ok.
At present, I have a modern E core coil (electronic ignition) mounted to an aluminum bracket, which is mounted to the intake, with teflon bushings (no metal to metal contact) to help insulate it from the intake heat, It's been like that for probably 14 years now, daily driven.
If you use a good quality coil, it probably does not really matter.
idealtrucks
Jan 2, 2023 03:13 PM
satter612
Nov 7, 2022 04:31 PM
fenix1
Bronco II
Jun 23, 2013 03:55 PM
Corkwheats
Feb 14, 2013 08:01 AM
