Looking for Ignition Switch Connector
Old Aug 29, 2023 | 11:16 PM
Ahrzee's Avatar
Ahrzee
3rd Gear
I've got a 1977 Ford F-150 (6 cylinder). Had some trouble starting it and traced the problem to the connector harness behind the ignition switch. Some wires are not being securely held in the connector. I can start it reliably if I remove the ignition switch from the dash, grasp the connector / switch assembly and turn the key.
So I'm trying to find a replacement connector for the wire harness behind the ignition switch. I can find lots of ignition switch bodies, but I need the connector not the switch. I tried searching for "ignition switch connector", "ignition switch harness connector", "ignition switch female connector", but can't find anything.
Is there a different search term I should be using? I'm considering trying to find a different year ignition switch, as long as I can get a matching connector for the back side.
Any ideas are welcome! Thanks in advance!
Old Aug 30, 2023 | 03:10 AM
Doosenberry's Avatar
Doosenberry
Ignition switch pigtail. 77 is a one off year with 73-76 and 78-79 having their own plug setups. I found that out when swapping out some ignition parts on my 77. I don't think its actually reproduced and the next time I find a 77 in the wrecking yard, I'll snag it as a spare. 77 has a few other one off parts/setups as well that I've noticed. Fun stuff.
Old Aug 30, 2023 | 09:28 AM
Citymorg's Avatar
Citymorg
If you follow the wiring diagram, you can also connect directly to switch with spade connectors, if you cannot find a pigtail to work.
Old Aug 30, 2023 | 09:53 PM
Ahrzee's Avatar
Ahrzee
3rd Gear
Doosenbury: I'll try searching for "pigtail". But I'm guessing there won't be many since it's a one-off. Thanks for the info!
Citymorg: Great idea about the spade connectors. It looks like the pigtail connector has worn / melted slightly so that's why the wires are loose. I may be able to just use spade connectors with some shrink wrap insulation tubing. Thank you too!
Last edited by Ahrzee; Aug 30, 2023 at 09:57 PM. Reason: Added response to all suggestions so far.
Old Sep 7, 2023 | 10:01 PM
Ahrzee's Avatar
Ahrzee
3rd Gear
I'm still looking for a pigtail, but in the interim, I took Citymorg's suggestion and connected the ignition switch wires directly to the pins on the back of the switch assembly. I removed each wire / plug from the connector by pushing a small locking pin away from the connector using a narrow screw driver. You can access the pins from the face of the connector opposite the wires.
I'm attaching a couple of pictures so folks can see the cracking (melting?) in the connector housing. It's mostly on the BAT connection. I think it's this cracking that allowed the wires to separate and made the igition only work intermittently.
It's great to have the truck starting reliably again! Thanks for the help.
File Type: pdf
File Type: pdf
Old Sep 9, 2023 | 11:37 AM
NM76F150's Avatar
NM76F150
My 77 looked similar but had a big crack on the side. I used JB Quick Weld to fix it. Cleaned all the connectors and so far it’s working great .
magnoliarunner
Jun 4, 2018 11:30 AM
Lookeee
Nov 26, 2011 05:55 PM
teppler
Sep 16, 2011 09:53 PM
1968stepside
Dec 21, 2003 08:03 AM
