I looked at the plate you told me about it has w.b 133 that I know is the wheelbase length color it has a T under it then it has body and under it it says F253 gvwr is 7900 original tire size was 7.50x16E
T = Red 1973/79.
btw: You have one hour to edit your posts, so you don't have to type new ones within that time frame to add comments.
OH thatis alright it is a nice bright red anyhow I was going by what the other site said you would know more than they do number dummy because you worked for ford thanks for the info
