6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 options repair replace engine 2008
Old Aug 25, 2023 | 11:06 AM
JRS2's Avatar
JRS2
Hi. I am new to diesels, so admittedly a newbie. Have read that this year is not good. Anyways found a mechanic special engine knocking. Does it make sense to replace w another size diesel, if so are there many issues getting it to run right, for instance computer swap or a whole lot more issues ? I'll start reading the forum to get more familiar but hoping for some general ideas .... thks ...
Old Aug 25, 2023 | 12:16 PM
knottyrope's Avatar
knottyrope
there are some reman engines out there
converting to something else might take a lot more work if you have never done it before
Old Aug 28, 2023 | 09:25 AM
Antonm23's Avatar
Antonm23
If you’re new to diesel, don’t start with buying a mechanics special 6.4.
They are among the worse (if not the outright worse) diesel engine to ever land in a mass produced consumer market vehicle.
They break often, are very hard to work on, parts availability sucks, and if you do find parts they’re expensive.
Old Aug 28, 2023 | 04:30 PM
DieselDenny's Avatar
DieselDenny
If you're new to Diesels and like to read and get your hands dirty...........you found the perfect tool to learn on.
They are great trucks when running right. What was said by Ant above is very true. Availability and cost of parts are explosively a factor.
If your not in too deep already, you will be financially. It's just not worth it. If you need a Diesel that's one thing, if your just tinkering, look over your shoulder for trail cams because you'll be tinkering alot.
What did you pay for it and what truck did you get?
Denny
Old Nov 16, 2023 | 05:21 PM
73fan's Avatar
73fan
Originally Posted by DieselDenny
If you're not in too deep already, you will be financially. It's just not worth it. If you need a Diesel that's one thing, if your just tinkering, look over your shoulder for trail cams because you'll be tinkering alot.
Denny
Nice way of saying it, Denny!
G.v.Mainberg
Mar 29, 2023 06:33 PM
saywhat333
May 27, 2021 05:59 PM
NIN
Mar 4, 2019 10:56 PM
Paramedic911
Dec 6, 2015 08:14 PM
FordF350Superduty
Ford vs The Competition
22
Dec 21, 2008 09:52 PM
