6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2009 6.4 Problem
Old Oct 10, 2023 | 09:40 AM
danny2313's Avatar
danny2313
2009 6.4 Problem
Good morning. i have a 2009 6.4 with a little over 300,000 miles. it has never had one single issue until a few weeks ago. it will crank and run like a top until it gets up to temperature, then it just dies.. once it cools off, it will crank right back up and then die when it gets to temp. there are no codes showing up and i have changed the fuel pump/filter on the rail. does anyone have any experience with this? Thank you in advance..
Old Nov 16, 2023 | 05:26 PM
73fan's Avatar
73fan
It would be interesting to note at exactly what temperature the shut-down occurs. Also, while you have the scan tool on it to monitor the temperature, monitor EBP, MAP, FRP, ECM voltage, FR temperature, MAF, IAT, and IAT2. Hopefully that would give you a good place to start looking anyway.
Old Nov 18, 2023 | 09:25 PM
DieselDenny's Avatar
DieselDenny
I think there is a thread about four years old stating the same symptom.
I believe it was a reading within the PCM to the sensor differences in the engine O/T and the trans O/T.
If I recall, the delta was 45 degrees. Bang, shut down. Cool down. Perfect until up to temp.
Sensors are cheap (OEM ALWAYS) sleep's not.
Denny
F250kelly
Apr 11, 2023 03:19 PM
Seanpk
Mar 26, 2021 04:59 PM
trimman
Dec 25, 2017 03:35 PM
pennmktg
Jan 6, 2015 07:21 AM
FordGuy85
Mar 21, 2012 03:09 AM
