6.2L V8 Discuss the 6.2L V8
rear differential cover
Old Aug 19, 2023 | 10:38 PM
Retired 2020's Avatar
Retired 2020
Trailering
2011 Ford F250 CC automatic what differential cover you all prefer as aftermarket?
Old Aug 23, 2023 | 06:23 AM
Akley88's Avatar
Akley88
Banks Power. i have had one pretty much since they were released since i did my swap at that time.
https://bankspower.com/collections/c...rential-covers
Old Aug 26, 2023 | 08:02 PM
Firefighter 1406's Avatar
Firefighter 1406
I just picked up one of the finned aluminum covers Ford threw on the 08-10 trucks. Not quite as fancy as an aftermarket one but better then the stamped steel cover. Plus it was only $40.
Old Aug 26, 2023 | 08:20 PM
Retired 2020
Trailering
Does it have a drain plug? If so what brand…..
Old Aug 27, 2023 | 10:25 PM
Firefighter 1406
No it doesn’t. Unfortunately.
Old Sep 1, 2023 | 02:29 PM
fire240's Avatar
fire240
I have the banks cover on my truck. Has a drain plug. Looks nice under there. Disregard the lift. I was getting some maintenance done that I can’t do at home.
Old Sep 3, 2023 | 12:04 PM
bent-1's Avatar
bent-1
USA STANDARD GEAR USA11429 Yukon Hardcore Differential Cover Info
Rear; with Ford 10.25 / 10.5" Rear Differential
Old Sep 3, 2023 | 12:09 PM
bent-1's Avatar
bent-1
Found this unit by USA Standard Gear. Has a drain plug, and also a fill plug.
Old Sep 6, 2023 | 09:28 PM
Lamoon78's Avatar
Lamoon78
Be nice if his butt would make one for the duallys
Old Sep 8, 2023 | 10:41 AM
Akley88's Avatar
Akley88
surprised he hasnt yet. also wish he would do a front diff cover
Old Sep 13, 2023 | 04:59 AM
Lamoon78's Avatar
Lamoon78
From what I been told when I’ve called and asked is basically its not a priority for the Ford dually but have them for Dodge and GM my guess is he won’t ever make one. The CS at Banks sucks to they are not nice people.
Old Sep 14, 2023 | 08:58 PM
Bugzilla46310's Avatar
Bugzilla46310
This is identical to the Ford but without the Ford logo and less expensive. Forgot where I found it online. Added paint and ss hardware.
Old Dec 23, 2023 | 03:38 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Dorman 697-725
Amazon Amazon
Mike in CA
Sep 11, 2022 03:36 AM
Big-1
Sep 7, 2021 04:51 AM
Ford79
Mar 7, 2009 09:05 PM
FordSDF250
Mar 5, 2008 03:21 PM
