Need E4OD help
Old Aug 17, 2023 | 03:21 PM
josiewales's Avatar
josiewales
Need E4OD help
1994 F250 460 E4OD 147,000 miles
Couple weeks back , while going up a grade heard a BANG under the hood. Stopped to investigate and think I found the air injection system blew a connection back at the firewall. It had already, some 11 months and 4,000 mile back, burned up the connections to the headers. Those rubber hoses have been plugged with bolts and hose clamps.
Anyway, now it has rough idle almost like a vacuum leak and the trans shifts very abruptly and had a noticeable exhaust smell in the cab. My mechanic got the exhaust leak stopped but read the codes and couldn't find anything else to fix.
The cat also has begun to rattle very noticeably.
Can the cat be stopped up and causing the idle and shifting issues ?
Old Aug 17, 2023 | 03:38 PM
sandymane's Avatar
sandymane
If you know how to run codes then suggest you run em. Something is going on that should cause a code.
Old Aug 17, 2023 | 08:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If the engine is down on power the trans will shift harshly.
Here is how to run codes: www.troublecodes.net/ford
Old Aug 18, 2023 | 09:44 AM
josiewales's Avatar
josiewales
My original post was unclear. The mechanic did read codes and said there were none to be had.
Old Aug 18, 2023 | 10:12 AM
Mark Kovalsky
I suggest checking on what the mechanic did. Read the codes and see if he ignored some of them. www.troublecodes.net/ford
coreyallan01
Jun 1, 2022 07:51 PM
Encho
1978 - 1996 Big Bronco
Feb 11, 2010 08:42 AM
78f3504x4
Jun 20, 2008 09:45 AM
waltmoe
Apr 9, 2004 12:47 PM
warriorpoet
Jan 8, 2003 02:07 PM
