Pulled engine, what to do?
Old Aug 16, 2023 | 03:08 PM
  #31
WNYPSDguy's Avatar
WNYPSDguy
Ah yes good one! I forgot about this. Allow to embellish and say that one should get the longer coils to get the Helicoil/Recoil through the full depth of the plate.
Insert Kit Metric Coarse M10.0 -... https://www.amazon.com/dp/B00A2LQXWQ...p_mob_ap_share
Absolutely go full depth with helicoils! The “3D” designation is the length of the insert - 3 times the diameter- so 3 x 10mm. This is as long as you can go with a helicoil in that spacer plate. The helicoil kit comes with shorties, I needed to order the longer 3D ones off Amazon.
Old Aug 16, 2023 | 03:12 PM
  #32
FordTruckNoob's Avatar
FordTruckNoob
Oops. I missed the 3D in your post. You had it covered!
Old Aug 16, 2023 | 04:54 PM
  #33
Steve0373's Avatar
Steve0373
Trailering
Originally Posted by 077tango
Where did you get your oil pan?
OEM Motorcraft through a reputable eBay seller.
Old Aug 16, 2023 | 05:18 PM
  #34
WNYPSDguy's Avatar
WNYPSDguy
Oops. I missed the 3D in your post. Youbhad it covered!
Hey Leonard, if you missed it others might too, so I’m gad you chimed in and made me explain further. When I pulled my starter, one bolt was only finger tight and the 2 bolts were different sized heads and different lengths… New bolts (with the mushroom head) from Napa at 40mm long are almost full depth in the helicoil.
Old Aug 16, 2023 | 08:10 PM
  #35
RacinJasonWV's Avatar
RacinJasonWV
Just FYI, I wouldn’t trust any eBay seller for the sensors and glow plugs. Oil pan is a different story though.
CNC Fab, Riffraff, DieselOrings. com to name a few known good sources.
Old Aug 16, 2023 | 08:46 PM
  #36
callforfire's Avatar
callforfire
Hows the timing cover look behind the lpop & water pump?
Old Aug 17, 2023 | 09:07 PM
  #37
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Lots of good stuff above. I'd definitely replace the HPOP lines, the fuel lines, reseal the fuel bowl (keep it) and install an FRX.
And a fuel pressure gauge, no way to measure that otherwise.
All this stuff I'm recommending can be easily done with engine in the truck. Basically high priority preventive maintenance any truck this age should get.
Other end of the truck, Hutch and Harpoon mods, same reason.
Old Aug 17, 2023 | 10:16 PM
  #38
Steve0373's Avatar
Steve0373
Trailering
Not sure...I'll check.
Old Oct 3, 2023 | 01:45 PM
  #39
Steve0373's Avatar
Steve0373
Trailering
Engine back and running again!
Thank you all for chiming in with helpful input. I just got the engine in the the truck and running a few days ago, so happy to have it back up again! And for the first time since I've owned it, it looks like it might be drip free
Thank you all again!
Old Oct 5, 2023 | 01:42 PM
  #40
Ford Motor Company's Avatar
Ford Motor Company
Official Ford Pro Rep
Hey Steve! Glad to hear you got your truck back up and running!
MDHunter
Apr 20, 2023 12:03 PM
AKHunter93
28
Nov 27, 2016 01:01 PM
WH90
Mar 5, 2011 01:22 AM
RaysDiesel
Oct 5, 2009 02:21 PM
pdvan
Feb 26, 2004 08:59 PM
