neutral safety switch
Old Aug 14, 2023 | 10:30 PM
ramrod66's Avatar
ramrod66
i learned the hard way that my '66 can and will start in gear!! took me by surprise.
is there a way to add a neutral safety switch to a truck that didn't originally come with one?
is there a way to add reverse lights to a truck that didn't come with them? i know the '67 tail lights have the reverse light, and it will interchange with a '66 tail light. i just don't know how the wiring would work.
Old Aug 15, 2023 | 01:42 AM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Cannot tell you how to add reverse lights to a Slick. But neutral safety switches are associated with automatic transmissions.
Old Aug 15, 2023 | 04:39 AM
Crop Duster's Avatar
Crop Duster
You have an NP435 I assume. No clutch safety switches until the 1980's. Thanks to scum bag tort lawyers. Backup lights and clutch safety you will have to redneck engineer yourself. Or just make sure it's in neutral before you start it.
Old Aug 15, 2023 | 08:56 AM
TA455HO's Avatar
TA455HO
Lead Gopher
To add backup lights to a Styleside you could get the 1967 taillight buckets and lenses as well as the taillight wiring. These are some of the pieces needed.
Taillight Housings Kit - 1964-72 Ford Truck, 1967-77 Ford Bronco | Dennis Carpenter Ford Restorations (dennis-carpenter.com)
Taillight Lens Kit - Lens and Gaskets - 1967-72 Ford Truck, 1967-77 Ford Bronco, 1967-72 Ford Econoline | Dennis Carpenter Ford Restorations (dennis-carpenter.com)
CJ Classic Trucks F-100 Taillight Wiring Harness With Taillight Crossover Harness USA Made 1967 (cjponyparts.com)
You could then get a tower from a 1967 or newer NP435 (assuming Crop Duster's assumption is correct here) which has the reverse lights switch built-in to it. The switch just provides a ground path for the backup lights.
Ford NP435 Manual Transmission Cover Shifter Tower NP 435 4 Speed New Process | eBay
These are some of what would be needed to do it like Ford did it. The other option would be to wire in a switch instead that you throw by hand when wanting to back up - or if wanting to freak out the driver behind you...
Old Aug 15, 2023 | 12:00 PM
ramrod66's Avatar
ramrod66
Man!! You guys are on it!! Yes, it's a 4 speed, I forgot to mention that. I'm very careful about how to start it now. But I'll take a look at these links to see what I can cobble together. Thank you!!
Old Aug 24, 2023 | 03:19 PM
William's Avatar
William
Easy reverse light is to just add a small light to the bumper and a toggle switch on the dash. Provides light when hooking up a trailer and backing in a dimly lit area at night.
Old Aug 24, 2023 | 08:58 PM
ramrod66's Avatar
ramrod66
i thought about something like that. it would be just like me to never turn it on while backing
Old Aug 25, 2023 | 11:42 AM
Tom H So. Ca.'s Avatar
Tom H So. Ca.
If your shift pattern has reverse all the way to right and up. It puts your fingers close to the dash, about where a radio is normally.
You could put a lighted switch on the dash with a magnet or velcro (trying not to have to drill holes) just in front of your fingers that would be easy to flip. Or somehow attach a switch to the shift lever near the ****. Also you could add a buzzer to remind you it's on.
Tom
Old Aug 25, 2023 | 12:08 PM
Crop Duster
Or you could just ride the brakes a little when you back up like we all did before back up lights.
Old Aug 25, 2023 | 01:40 PM
Tom H So. Ca.
For the neutral safety. You could rig up a switch (and maybe a relay) to the clutch pedal that would interrupt the starter wire from the key switch. But with this, you would have to hold down the clutch pedal anytime you start the truck.
Just a thought,
Tom
Old Aug 27, 2023 | 12:37 PM
ramrod66's Avatar
ramrod66
i think my ultimate solution is to wait for an engine and tranny upgrade and it'll fall into place naturally.
i've been looking for a ford motor to put into the truck, but they aren't in my price range. unfortunately (or, fortunately) the LS motors are cheap and plentiful. and the aftermarket is ripe with parts.
i'm sure i just opened a can of worms.
Old Sep 8, 2023 | 01:49 PM
William's Avatar
William
How about this...install a push button switch low on the right side of the steering column in the starter wire from the ignition switch to the starter solenoid. Get in, push in the clutch, push the push button switch, turn the key and start the truck. Might be a good and easy anti theft device as well.
Old Sep 9, 2023 | 04:02 AM
Thunderkiss1965's Avatar
Thunderkiss1965
I did that in my BMW. Flip the toggle a bunch of times and tailgaters drop back right away!
BadMoFo
29
Mar 10, 2025 11:35 PM
wreckinball
Jun 1, 2010 02:32 PM
soulbucket
Apr 18, 2008 08:50 PM
47namrrapom
Feb 20, 2008 11:54 AM
rick
1978 - 1996 Big Bronco
Apr 30, 2000 12:17 PM
