Front right hub getting hot
Old Aug 11, 2023 | 03:22 AM
AllF150s's Avatar
AllF150s
3rd Gear
I have a lift and oversized wheels on a f150 FX4 and the breaks got hot enough to start the ABS sensor on top to catch fire for a second, immediately extinguished. I figured the calipers stuck and got hot. Prepared to replace the rotors the breaks and the calipers I took them apart. That’s when I found the ABS sensor connector on the top of the hub melted and the breaks almost brand new and almost unused and the metal of the calipers on the top outside and bottom inside worn down and polished. The axil nut was stripped and the axil bolt was curved up. Obviously the axil needed to be replaced and the hub because the wheel was cocked at an angle. Replaced the axil and hub and had the rotor turned and now the exact same thing is happening. The metal of the calipers is doing the breaking and the hub is way hotter than the opposite wheel. What did I miss?
Old Aug 11, 2023 | 04:10 AM
RLXXI's Avatar
RLXXI
Check to make sure you have the pads installed correctly. There is an inboard and outboard pad that can be determined by the humps. The pads with humps go to the inside and the ones without go on the outside. If you mix them up, it can cause your concern.
Old Aug 11, 2023 | 10:48 AM
AllF150s's Avatar
AllF150s
3rd Gear
When I put it back together I reversed them from what they were originally, I used the same pads since they were virtually unused. I didn’t know that there was a difference in pads. But again I’m breaking with the metal, just like before, like the rotor is mounted at an angle
Old Aug 11, 2023 | 11:51 AM
RLXXI's Avatar
RLXXI
If the pad with humps is on the outside it will make the caliper ride cocked at an angle causing it to bind with the rotor. The humps go inside against the caliper pistons on both sides, the out board pad is smooth.
Old Aug 11, 2023 | 04:13 PM
AllF150s's Avatar
AllF150s
3rd Gear
Thanks guys, apparently the first time was due to the bad hub, this last time it was because I reversed the pads. Mounted the properly and I have even wear on the pads and the hub is the same cool temperature as the other side. Since I’m new to this forum, now that this issue is resolved how do I end this or do I leave it for others?
Old Aug 11, 2023 | 04:18 PM
RLXXI's Avatar
RLXXI
You're welcome.
Old Aug 13, 2023 | 06:22 PM
rbentnail's Avatar
rbentnail
Glad it was found, the reversal of pads is the first thing I thought of too. Just leave the thread as is, it's the first one on this topic we've seen this year and will be a good reminder for everyone.
Old Aug 14, 2023 | 10:29 AM
seventyseven250's Avatar
seventyseven250
The thread will ether end by itself due to lack of interest, or others with similar issues will keep adding on. Either way, nothing you need to do about it, other than chime in if you have something to add.
pvdiag
Aug 17, 2021 11:23 PM
r___r
Jul 4, 2017 09:24 AM
TKegs763
Sep 25, 2013 07:45 PM
blackbetsy
1978 - 1996 Big Bronco
Sep 30, 2011 01:55 PM
dancedad
Feb 1, 2009 12:37 PM
