Fuel pump leak?
Old Aug 9, 2023 | 11:51 AM
  #31
Dailydriver22's Avatar
Dailydriver22
It was similar to the harbor freight one but it was an autozone rental kit. Not too familiar on the types of flares but it flares out on both ends and seals
Old Aug 9, 2023 | 04:43 PM
  #32
BigBlue2's Avatar
BigBlue2
When you inspected the old line where did it crack and leak?
Old Aug 9, 2023 | 05:02 PM
  #33
Dailydriver22
I did not see any cracks or holes of any kind on the old pipe, but it was leaking out of the fitting that goes to the pump. Both from the threads and from the center of it, no matter how much I tried resetting that end and making it as tight as possible it was still shooting out. Looking back on it I probably could have just used gasket maker on the old one but oh well. What’s done is done
Old Aug 9, 2023 | 10:03 PM
  #34
BigBlue2's Avatar
BigBlue2
Very interesting that you had a leak in the same place as before but with new pump and fuel line. What are the chances?
If it starts leaking again maybe tighten the nut more using a flare nut wrench. You can get better purchase with the right wrench.
Old Aug 9, 2023 | 10:06 PM
  #35
Dailydriver22
I did use a flare nut wrench, that was the only one I had in 16mm surprisingly enough so I used that and another wrench pried between the two ports to keep myself from breaking the pressure fitting
Old Aug 9, 2023 | 10:09 PM
  #36
BigBlue2's Avatar
BigBlue2
Sounds like you snugged it proper. I guess save the old pump as it's probably still good. Maybe that's the silver lining to this story.
Old Aug 9, 2023 | 10:12 PM
  #37
Dailydriver22
Yeah I planned on saving it since the gasket on it was completely blown out on the top side I figured the pump was still good. Got my old radiator to rebuild, and my old master cylinder to do as well. Finally getting a nice collection of parts that need rebuilding. Maybe I’ll get around to it once I’m done putting new parts on this thing
Old Aug 10, 2023 | 12:38 PM
  #38
Larry1#'s Avatar
Larry1#
Can anyone on this thread tell me whether it's ok to install an electric fuel pump under the hood as opposed to underneath the truck at the level of the fuel tank? The lines coming out of the fuel selector valve are a hard plastic or nylon material and I think they require a special tool, so I'd rather not mess with them.
Old Aug 10, 2023 | 12:42 PM
  #39
tjc transport's Avatar
tjc transport
i ain't rite
I have my facet mounted to the fuel filter bracket.
the facet duralift will lift 10 foot straight up.
it was designed for refrigerated trailer use.
uuuhCharlie
Mar 15, 2022 08:34 PM
BBslider001
Ford Truck Parts for Sale
Jun 21, 2017 07:35 PM
ncinirator
Jul 16, 2014 05:28 AM
Shaun lindmark
Feb 28, 2010 03:32 PM
