Fuel pump leak?
Old Aug 7, 2023 | 08:35 AM
Dailydriver22's Avatar
Dailydriver22
Fuel pump leak?
Hello,
This morning I found out about a new leak that is pretty bad if I might say so myself. I believe it’s the fuel pump but I could be wrong. Has two hoses going into it, mounted on the lower pass side of the front face right behind the vacuum pump. Smelled like diesel inside the engine bay and the liquid was runny not like oil. I know this needs to be fixed but how high is the risk if I continue driving it until payday at the end of the week? (The pic was taken from underneath the engine)
Old Aug 7, 2023 | 08:43 AM
knottyrope's Avatar
knottyrope
once the headers get hot enough, it can go up in flames
degrease, wash and let dry and hunt for the leak
that looks like spray from some where and maybe not the actual pump
Old Aug 7, 2023 | 08:47 AM
Dailydriver22
I got a look at it with the engine running and it was in fact coming from that part circled. Wether it’s where it connects to the motor or from the hoses I’m not sure since visibility is hard in there. My drive to work is just over 10 miles and I’m already at work so I’d have to drive it home regardless. Funds are low at the moment but I’ll see what can be done
Old Aug 7, 2023 | 08:57 AM
Olds64's Avatar
Olds64
It looks like the hose barb on the right is missing a hose clamp.
Old Aug 7, 2023 | 09:07 AM
Dailydriver22
I don’t know where the clamp would’ve gone but I could slap a piece of tie wire on the line to get me home. I guess that’ll tell me wether or not is the line or the pump itself
Old Aug 7, 2023 | 09:43 AM
BigBlue2's Avatar
BigBlue2
If you can source a hose clamp nearby that would be best. Tie wire can damage the hose. If the hose clamp solves the leak issue you're good to go.
Old Aug 7, 2023 | 09:48 AM
Dailydriver22
Just watched a video on replacing that lift pump and it looks like that hose doesn’t have a clamp like the other one does. That hose goes inside the fitting and secures to it somehow. In the video the guy mentioned how his cracked on that fitting and that’s where his leak was. Don’t think there’s any type of securing I can do that’ll work on this
Old Aug 7, 2023 | 09:50 AM
BigBlue2's Avatar
BigBlue2
Besides the leak and smell of fuel did you notice any engine performance issue? When my lift pump failed I noticed reduced power. It was dripping fuel too.
Old Aug 7, 2023 | 09:57 AM
Dailydriver22
I didn’t notice any difference from the other day to today but a week ago I did new oil, fuel, and air filters, ran diesel kleen through my tanks and filter, and changed the oil. That was when I noticed a change in engine pitch and a reduction of power. Figured that was due to the air filter since that was the first time I ever changed that on this truck. Today however I had no issues and didn’t notice anything off about it
Old Aug 7, 2023 | 09:58 AM
BigBlue2's Avatar
BigBlue2
Rather than tie wire if I had access to a piece of insulated #12 or #10 copper wire I'd go with that as it will be more kind to the fuel line.
Old Aug 7, 2023 | 10:38 AM
Dailydriver22
The one that’s leaking is secured by the fitting itself. The hose inserts and the fitting tightens around it so I’m gonna try tightening it and then putting a rag around it to get me home
Old Aug 7, 2023 | 02:39 PM
BigBlue2's Avatar
BigBlue2
A rag won't help. It's only going to get soaked and be a fire hazard. Better to let it drip. If it's me I either leave the truck at work and show up with parts and tools and make the repair there or have it towed home.
If I'm driving home because the tow dough is too high, I'd let it drip away. Not accumulating in a rag.
Old Aug 7, 2023 | 05:23 PM
tjc transport's Avatar
tjc transport
i ain't rite
sounds like the steel line has a crack in it, probably at the flair where it seats on the pump behind the nut.
Old Aug 7, 2023 | 06:27 PM
Dailydriver22
Picked up the new fuel pump and was able to drive home with minimal bogging, and only a little bit of smoking from underneath the engine. Followed your advice and didn’t put a rag on it, just kept my rpm’s below 2500 and made sure to accelerate slower than any grandpa out there. It’s 105 out right now and I don’t have any shade and only asphalt to work on so I’ll be taking care of this matter in the morning.
Old Aug 8, 2023 | 08:00 AM
Olds64's Avatar
Olds64
I hope installing the new fuel pump fixes your leak. Make sure you get an early start. It's been 100°+ here in OK lately too.
