hard to start......
Old Sep 7, 2003 | 10:07 PM
TexasRanger69's Avatar
TexasRanger69
Unhappy hard to start......
I need help on how to reair or fix my 89 F250 morning start up problems.........my "wait to start" light will only stay on for about a second and it just wont start unless you just turn on and off about 60 times and it seems to flood itself.....white smoke comes out till it finally does start and you can smell raw fuel..........im sure its a simple fix, but this is my first ford diesel ................any ideas?
Old Sep 8, 2003 | 01:05 PM
nogo73's Avatar
nogo73
hard to start......
glow plugs you are suppose to have white smoke during start up
Old Aug 10, 2023 | 10:31 AM
Sarahps33's Avatar
Sarahps33
I'm having a similar issues, did you ever figure out what was going on? I'm wonder why you had to turn the key on and off over and over again like having to keep pulling fuel up there. I don't think that's what I got going on, but I am having a hard time getting it started and the white smoke is crazy.
Old Aug 10, 2023 | 10:58 AM
BigBlue2's Avatar
BigBlue2
The glow plug controllers are famous for screwing up. Bypass the controller and use a momentary button to the glow plug relay. 6 seconds on a cold engine at temps above freezing is good. If really cold up to 10 seconds. Say 6 seconds at 40 F and add a second for every 10 degrees colder.
Old Aug 10, 2023 | 03:28 PM
tjc transport's Avatar
tjc transport
i ain't rite
he has not logged on in 20 years.
first thing to do is check the glow plugs.
if they are not motorcraft plugs, they are most likely burned out. which is a symptom of the one second WTS light.
try plugging the block heater in for 2-3 hours. if the engine cracks rite off, the glow plugs are not working.
Jesses1999f250
Feb 6, 2015 10:22 AM
rayjamesfun
May 14, 2013 11:24 PM
JamesHajek
Jan 20, 2010 11:51 PM
phillips91
May 2, 2008 02:46 PM
Gr8ride
13
Sep 14, 2001 08:09 PM
