Bleeding clutch hydraulics
Old Aug 9, 2023 | 07:27 AM
FordTruckNoob's Avatar
FordTruckNoob
Pure curiosity on my part since I have a 4R100: Have any of you tried a reverse pressure bleed i.e. push fluid in through the bleeder nipple at the slave?
Old Aug 9, 2023 | 09:03 AM
Tpayne621's Avatar
Tpayne621
They have no bleeder nipple at the slave.
Old Aug 9, 2023 | 09:04 AM
Tpayne621's Avatar
Tpayne621
Originally Posted by Sous
Here is the solution that Timmyboy76 came up with a couple years ago. I never got around to doing this even though I have the parts in a bag in the garage. That seems to be a theme around here for us on the FTE...
https://www.ford-trucks.com/forums/1...l#post16202528
That's basically same exact thing the heim joint kit does.
Old Aug 9, 2023 | 09:20 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
That is correct sir, just another way of achieving the desired result.
Old Aug 9, 2023 | 09:54 AM
FordTruckNoob
That explains a lot. Who the hell designs a hydraulic system with no bleeder at the terminus?!
Old Aug 9, 2023 | 12:33 PM
dsrace's Avatar
dsrace
I am to the point with my e99 that it time for this mod. Not a hard heim joint to add but I do wonder if part of the problem is the shaft that the entire arm pivots on? I ask this because in the 92 obs I had, that was the case along with the shaft the clip locked down on. Now in the case of my e99, that shaft on the clutch pedal has some wear on one side, clips don't blow off and a new clip does wonders for about 4 pumps and then its back to the floor. Hard to see for sure but there is a fair amount of play and it doesn't look like its all from the head of that rod.
Old Aug 9, 2023 | 02:59 PM
knottyrope's Avatar
knottyrope
they designed the bleeding with out the need of any tool
Old Aug 9, 2023 | 03:07 PM
FordTruckNoob
Okay. I will take your word for it since I have never worked on a SuperDuty's clutch. Every other clutch I have worked on had a bleeder at the slave.
Old Aug 10, 2023 | 04:06 PM
dsrace's Avatar
dsrace
this is not video of my pedal assembly but i believe the play i am seeing up at the pedal. not surprised at the wear with 142 k miles on the truck. forward to 8:00 and watch the left side of the pin the pedal pivots on. that slop add to the issue.
cinbearcat
Escape & Escape Hybrid
Nov 30, 2013 05:52 PM
4601ton
Jan 5, 2013 08:55 PM
chrisginco
Sep 3, 2012 07:53 PM
DT 466Man
Jun 27, 2005 07:57 AM
