Airboats
Old Aug 3, 2023 | 01:28 PM
sky Cowboy's Avatar
sky Cowboy
Airboats
I'm dreaming about building an airboat.
Has anyone here done so?
Advice?
I have an airplane engine and prop I've thought about using, but is that best?
Open to all tips.
Old Aug 3, 2023 | 02:17 PM
RLXXI's Avatar
RLXXI
Advice?
Open to all tips.
Most of the airboats I've seen down here (thousands) all seem to use automotive water cooled engines like Ford and Chevy, small and big block with some sort of prop speed reducer drive. That's about all I can tell you. Perhaps you'll glean some info from this link. https://www.southernairboat.com/comm...-engine.69580/
Old Aug 3, 2023 | 03:28 PM
tjc transport's Avatar
tjc transport
i ain't rite
newer technology is automotive water cooled engine.
old technology was an air cooled 4 or 6 cylinder horizontally opposed engine, like a Volkswagen 4 , or Lycoming 6 plane engine
Old Aug 3, 2023 | 06:19 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Also...
If you use an aircraft engine be aware they are not what you are familiar with for maintenance or repair.
Do you have an aircraft engine parts supplier on almost corner everywhere you would go or maybe a corner store for automotive engines?
Old Aug 4, 2023 | 06:17 AM
JWA's Avatar
JWA
I was pretty much under the impression the old VW opposed 4 cylinder air-cooled engines were more than enough power---and easy as crap upkeep and maintenance too.
Blast from the past about one air boat:
Old Aug 4, 2023 | 07:26 AM
BassFantasizer's Avatar
BassFantasizer
It sounds like a fun project. You've got most of the major pieces. With the right boat you're ready to start fabricating. Note that you probably don't want to build your own boat. I'd suggest finding a hull from an old airboat and using it.
If you've never been around airboats, be cautioned that they're special purpose craft. They're loud. You cannot talk with anyone else in the boat with the motor running. There's a reason that the tours hand out earmuffs to their riders.
It used to be that the straight pipes was all the "muffler" needed. That's not true everywhere today as the number of airboats has grown and people with expensive lake-front property don't want an airboat's noise that close to the house. The law wouldn't let your next door neighbor create that kind of racket on land and the laws are catching up to limit airboat noise.
Some of the newer props do a better job of moving through the air with less noise. I have no idea what their availability and costs are.
Just some things to factor into the equation. (But it's hard to argue against any project that results in a functional boat!)
Old Aug 4, 2023 | 09:56 AM
sky Cowboy's Avatar
sky Cowboy
An IO 550 will weigh a lot less than a V8 automotive engine, and also doesn't need a radiator, fan, etc.
I'm very used to aircraft engines and their maintenance, which really isn't that bad at all.
I rebuilt the IO 550 myself, except the mags which I sent out to be rebuilt.
Thanks everyone.
Old Aug 5, 2023 | 05:42 AM
JWA's Avatar
JWA
Please keep us updated if this project yields anything---it would be interesting I'm sure!
Old Aug 5, 2023 | 07:46 AM
RLXXI's Avatar
RLXXI
Thanks everyone.
What about the huge cost difference and availability of av gas and pump gas? Down here there's plenty of docks where you can pull in and fill up if needed with pump gas, don't remember seeing any places on the bayou with av gas except maybe the occasional seaport. Or can your engine run on pump gas?
Old Aug 10, 2023 | 09:10 PM
sky Cowboy's Avatar
sky Cowboy
Most marinas here sell 94 ethanol free gas, and it will run just fine on that.
Aviation gas as we've known it for many decades is about to change to.
There is also no chance of vapor locking due to high altitudes, as it will not ever be up high, which is something else that avgas helps with over pump gas.
It will never be used above 5000'.
Old Jul 27, 2024 | 04:58 PM
sky Cowboy's Avatar
sky Cowboy
Well it is now 11 months later, and I've done nothing with this.
Life sort of got in the way of building an airboat.
Built a house, bought more farm land, and moved this week.
Pretty much been working 7 days a week, 12 plus hours a day.
Since life should be slowing down some now, I hope to within the next year build an airboat.
BassFantasizer
Nov 4, 2021 09:19 AM
punkndrublic
Mar 28, 2003 10:28 AM
Fun in a Ford
38
Mar 24, 2002 04:26 PM
