Engine Dies when Clutch is Pressed
Old Aug 1, 2023 | 02:31 PM
Alan Martin's Avatar
Alan Martin
7th Gear
Thumbs down Engine Dies when Clutch is Pressed
I own a '95 F-350 with the 5.8L (351 Windsor) 2x4. When I press the clutch pedal the engine dies. I have replaced the Vehicle Speed Sensor (VSS, Rear Differential Mounted) and the Idle Air Control Valve (IAC). When I disconnect the battery and ensure the truck is fully dead It works for a little while after I reconnect the battery, then reappears.
What do you advise? Could the Clutch Pedal Position Switch be an issue?
Last edited by Alan Martin; Aug 1, 2023 at 02:32 PM. Reason: incorrectly typed 5.9 instead of 5.8
Old Aug 1, 2023 | 05:04 PM
94ZR580's Avatar
94ZR580
Do you depress the clutch pedal when starting the engine? Does it start and idle properly? Maybe the ignition lockout is connected backwards? You should have to fully depress the clutch to start the engine. It would seem to be an electrical issue.
Old Aug 1, 2023 | 05:19 PM
Alan Martin
7th Gear
I do press the clutch to start the engine. It dies unless I quickly remove my foot from the clutch (in neutral). Then it idles low and returns to normal until I press the clutch again, which kills the engine. I will look into ignition lockout. Thank you!
RUSTANG67
Mar 14, 2007 10:59 PM
meck1
Nov 20, 2006 09:14 AM
eyyu
Jun 13, 2006 08:00 PM
boingo96
1997 - 2003 F150
Apr 8, 2006 08:57 AM
