HELP: What does EEC Clutch Switch do???
Old Oct 30, 2006 | 05:02 AM
meck1's Avatar
meck1
I've just replaced my manual tranny with a C6. On the straight shift clutch pedal, there were two switches on my '87 F250. One is the neutral lockout that keeps you from starting the engine without the clutch depressed. The other, according to my wiring diagram, is an "EEC Clutch Switch." I want to remove it, but will doing so have any effect on running? I can't tell any when driving with it either clutch pedal up or clutch pedal down, but I wanted advice from you with more experience. When I remove it, should I leave it with circuit "open" or "closed?"
Any help will be appreciated. Thanks.
Old Nov 18, 2006 | 05:29 AM
meck1's Avatar
meck1
Posting again: Question about EEC clutch switch.
Old Nov 19, 2006 | 06:07 AM
meck1's Avatar
meck1
I found the answer to my own question. For anyone else interested, the EEC clutch switch goes to pin 30 of the EEC. Clutch disengaged leads to a richer fuel mix to prevent stalling upon reengagement.
Old Nov 19, 2006 | 09:45 AM
projectSHO89's Avatar
projectSHO89
Actually, the PCM responds by raising the idle (IAC valve) so the engine doesn't stall.
When the IAC opens, the PCM also slightly lengthens the injector pulsewidths to give it a bit more fuel.
Steve
Old Nov 20, 2006 | 09:14 AM
MisterCMK's Avatar
MisterCMK
That switch will also disengage the cruise control
