Exhaust setup build
Old Jul 30, 2023 | 03:22 PM
Acblair's Avatar
Acblair
8th Gear
Exhaust setup build
I've got a 95 F 150 xl 5.0 and I'm thinking of putting together a custom exhaust system and I was curious to see if anyone had any set up recommendations.
I'm thinking of starting with some long Tube headers because mine is about to rust out, then I belive I'll have to custom fab a y pipe due to I can't find just the y pipe and to top it I have a widowmaker muffler so I don't get neighborly threats.
I hear there's a bunch of fitment issues with LTs but ive heard of some with minimal changes and im not opposed to shortys I just assume they need more fab work due to the cats being deleted.
Any thoughts are appreciated and yes I know I'm a pine cone. 👍
Old Aug 7, 2023 | 05:29 PM
Conanski's Avatar
Conanski
Actually short tube headers are easier to use as they are compatible with stock replacement Y pipes, so no fabrication is required and the whole system can be a simple bolt-on. Do not try to use Mustang shorty headers on a truck, they won't mate with a truck Y pipe and will hit the frame and/or firewall.
That said longtubes are better suited to the stock engines powerband, an appropriatekly sized system will produce noticable gains(over stock) at the lowest rpms. I have used a local muffler shop to fabricate a Y pipe for longtubes and have also built my own from mendrel bent sections, both worked well but I went too big with my DIY effort and as a result actually lost some off idle response and the system was louder than I would have liked. The best performing system I ever had on a truck 5.0 was a complete MAC system that consisted of 1.5" tube longtubes and a 2.5" midsection, unfortunately I think that company is now gone but that system could be replicated using other brand products. Also note that the cheapest Flowtech and Holley longtubes are not the best fit, they mostly clear everything but they hang too low and are too long and create clearance issues at the transmission crossmember.
Old Aug 9, 2023 | 08:51 AM
Acblair's Avatar
Acblair
8th Gear
Alrighty, I've seen a few of the longtubes like headmans but hear nothing but fitment issues. How is the performance with shorty headers on the 5.0 truck? I've heard that a 1.5 long tube and a 2.5 midsection is good so hearing it twice makes me lean more towards that. I don't mind fabrication, I do it and welding alot but you know, time is money lol
Obscure69
Dec 28, 2022 04:15 PM
SuperDutyScaler
Apr 30, 2010 03:52 PM
Southern Boy
Exhaust Systems
Dec 25, 2008 02:26 AM
Mrboylston
Oct 8, 2008 08:33 AM
Bugzturbo
May 22, 2007 07:44 AM
