unknow flashed codes 91 F250 inline 6
Old Jul 18, 2023 | 12:52 PM
jmczzz's Avatar
jmczzz
Trailering
My check engine light comes on and off intermittently. I get these codes flashed but do not know where to start to follow thru with fixes.
Suggestions or next steps, please?
327 DNT EVP Sensor
565 K06
I was told the 327 code is from the exhaust gas recirculation system. I do not know anything about this or how to fix it.
I do not know what the 565 code refers to. The Mechanic was vague in his response to my ask for what it refers to.
A professional shop hooked my truck to their diagnostic computer and gave me this info. Charged me $47.48 for this info.
Old Jul 18, 2023 | 02:21 PM
jas88's Avatar
jas88
The EVP (EGR Valve Position) sensor sits on top of the EGR valve and tells the computer if the EGR valve is opening or not. In my experience, it's usually the sensor at fault rather than the EGR not opening.
Old Jul 18, 2023 | 06:06 PM
wwhite's Avatar
wwhite
327 | EPT/EVP below min. voltage.
565 | Canister Purge (CANP) ckt. failure.
Old Jul 19, 2023 | 11:24 AM
jmczzz's Avatar
jmczzz
Trailering
codes decpher
Thank you both for this info. can you tell me where the EGR valve is located?
And what the Canister Purge (CANP) ckt. failure code indicates ad how to correct?
Thank you for the help. jmc
mlj1st
Nov 1, 2016 05:27 PM
IJRoorda
Jul 21, 2011 08:18 AM
djbeck88
17
Feb 2, 2011 05:00 PM
mcastleberg
Aug 13, 2003 11:11 AM
