Decode data plate for 65 ford
Old Jul 12, 2023 | 06:40 PM
65ArmyGopher13's Avatar
65ArmyGopher13
Would someone be able to decode this for me.
Vin: F26DR675794
WB 120
Color 120
F260
Body D81
Trans N
Axle 25
Max GVR 6800
Net hp 172
Rpm 4000
DSO 72
Old Jul 13, 2023 | 09:53 AM
James_Western_Canada's Avatar
Here's a link that has all the info you need to decode your data plate:
https://www.fordification.info/vindecoder.htm
And if you want a shiny new data plate, this is the place.
https://www.martiauto.com/tags.cfm
**Check to see if rivets c/w New tag before you add them to your order
https://www.martiauto.com/itemselect...lecteditem=yes
Old Jul 13, 2023 | 10:13 AM
TA455HO's Avatar
TA455HO
Lead Gopher
F26 - F250-4x4
D - 352 2V
R - San Jose, CA assembly plant
675794 - April 1965 assembly month - 1965 model year
120 - wheelbase in inches
T - Navaho Beige
F260 - F250 4x4 6800 Lbs. GVWR
D81 - D = Light beige crush vinyl and medium beige ladder pattern woven plastic - 81 = Custom Cab (in the context of D)
N - NP435 4-speed
25 - Dana (Spicer) 60 4.56:1 ratio non-limited slip
06800 - Gross vehicle weight rating
172 - Horsepower @
4000 - RPM
72 - San Jose district sales office
Marti does want $3.00 more for the rivets. They don't come with the reproduced data plate, so you have to add them to your order if you want them.
Old Jul 13, 2023 | 10:26 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Another forum member posted a truck with one less of a sequence number. However, it was built at the Michigan Assembly so not the same plant.
VIN Decode Please! - Ford Truck Enthusiasts Forums (ford-trucks.com)
ccarrier
Mar 8, 2022 07:24 PM
bigblock466
May 20, 2015 06:22 PM
dirtfloor
Feb 2, 2009 03:06 PM
towmaster
Mar 26, 2007 03:05 PM
