VIN Decode Please!
Old Mar 3, 2015 | 03:35 PM
wiesman2613's Avatar
wiesman2613
VIN Decode Please!
Hi all,
Can you please decode this VIN for me?
F10DL675793
WB 115
COLOR A
MODEL F101
BODY E81
TRANS A
AXLE 07
Thank you!!
-wiesman2613
Old Mar 4, 2015 | 03:20 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by wiesman2613
Hi all, can you please decode this VIN for me?
F10DL675793 / WB: 115 / COLOR: A / MODEL: F101 / BODY: E81 / TRANS: A / AXLE: 07 / MAX GVW LBS: 4200 / CERT NET HP: 172 / RPM: 4000 / DSO: 21
F10 - F100 2WD
D = 352 2V
L = Michigan Truck Assembly Plant.
6757793 = 1965, assembled April 1965.
115" Wheelbase.
A = Raven Black.
F101 = F100 2WD, 4,200 lbs. GVWR
E81: E = Red Crush Vinyl & Red Ladder Pattern Woven Plastic / 81 = 81B Custom Cab.
A = Ford type 3.03 3 Speed all Syncromesh Manual Transmission.
07 = Ford 9" Rear Axle / 3.25-1 / 3,300 lbs. Rear Axle Capacity.
4,200 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
21 = Atlanta GA Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Mar 4, 2015 | 07:00 AM
wiesman2613
Bill,
Thank you for the decode it is greatly appreciated.
Here is a picture of the warranty plate the DSO is not stamped.
And also a couple pictures of the truck too... it doesn't look like it has been messed with too much, I'll be finding out soon... Also what is that on the dash? I havent seen this before.
Old Mar 4, 2015 | 08:06 AM
svolpone's Avatar
svolpone
my grandfather had a fairlane with the same color scheme. always liked that black exterior, red interior look. nice truck.
Old Mar 4, 2015 | 10:28 AM
daveengelson's Avatar
daveengelson
Nice truck; although I am some what tainted in that my 65 with the 390 is identical, interior/exterior. If referring to 'that thing on the dash' I suspect prior owner installed an after market gauge of some sort, perhaps a tach, I have never seen an instrument mounted on the dash before??? Wow, the grille and front fender emblems appear to be in great condition, am sure aware they are hard to come-by.
Old Mar 4, 2015 | 12:14 PM
wiesman2613
Here is the gauge:
A "Gas Master" definitely looks to be of the era, however since I was born a generation after this truck was built I have never seen anything like it.
Old Mar 4, 2015 | 12:56 PM
SuperSabre's Avatar
SuperSabre
That's just a fancied up vacuum gauge. Looks period correct, but not a Ford (Rotunda) accessory. Ford put dealer add-on (and maybe factory?) clocks and tachs up on the dash in '63 - '65 cars such as Falcons and Galaxies (and maybe F100s?). Got a bit more integrated looking with the '64 - '66 Mustang Rally Pacs. Still, a fun piece and useful, too. Nice looking truck!
Old Mar 4, 2015 | 04:21 PM
wiesman2613
Thanks all for the comments on the truck it is appreciated, it is now officially bought and I'll be driving it home this weekend.. paid a tad bit more than I expected but since this truck seems to have most everything original I think it was worth it. Here are a few more pics:
Old Mar 4, 2015 | 04:28 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Looks to me like your DSO is 21 - Atlanta, GA
The numbers don't always line up directly under the headings. Some are worse than others.
Old Mar 4, 2015 | 05:22 PM
daveengelson
With the additional pic's the truck looks even better. Certainly is a fancy looking Vac. gauge, " gas master"; if anything like the 390 in my 65 I would be hovering around 5-6 in the 'power range' reminding me I am getting between 8-9 MPG.
Old Mar 4, 2015 | 05:41 PM
wiesman2613
Thanks Dave, haha at least the gas prices now are back to being somewhat reasonable! I'm sure the 352 isn't much better, glad this is going to be a around ton fun to drive on the weekends type truck.
I want to keep this thing original as possible as well because of how complete this thing is. I'm definitely nervous to see the cab mounts and core support up close and personal for the first time, but from the pictures I requested it looks solid.
One more question for everyone, what is the best way on a 352 to make sure it is original to the truck?
Old Mar 4, 2015 | 05:43 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Unfortunately, no way to tell if an engine is indeed 100% original to the truck. GM stamped the partial VIN number on the engine blocks, but Ford never did anything in these trucks to help determine those sorts of details.
It is possible to tell if an engine is not original to the truck and you can use the engine block casting date to try to determine if you *think* it might be the original, but no way to know for certain.
Old Mar 4, 2015 | 10:22 PM
wiesman2613
That's a bummer, as I want to keep this one as original as possible. The vin is stamped on the frame on the passenger front side right?
Old Mar 14, 2015 | 11:42 AM
wiesman2613
I just got it home and in the garage
Now the fun begins... Can someone tell me the build date /any other information about my motor from this engine tag?
Here is a picture...
[/URL]
Old Mar 14, 2015 | 05:11 PM
NumberDummy
Bill,
Yes it is.
21 = DSO code edited into post #2.
Post 14 = engine ID tag code:
Top Line: 352 (engine size) / 65 (1965) / 5 (engine plant code).
Bottom Line: 5D (engine assembled April 1965) / 801 J (352 2V).
