Fuel pump
Old Jul 12, 2023 | 09:45 AM
Durk978's Avatar
Durk978
Trailering
Fuel pump
Good morning fellow 7.3 owners. So I have a weird question and I honestly don’t know where to start. So I was going to change out the fuel pump on the side rail and come to find out the one I purchased was wrong. The one that is currently on the truck is for a 6.0. Do they work the same? I believe going on it’s way out and need a vehicle to get to work. What can I do about this issue to be resolved. Thanks again.
Old Jul 12, 2023 | 10:00 AM
Tpayne621's Avatar
Tpayne621
Hmm. That's a first. Haven't ever heard of anynody doing that before. It's a totally different setup with a built in filter.
Old Jul 12, 2023 | 10:09 AM
Kwikkordead's Avatar
Kwikkordead
I didn't know the 6.0 pump is so much different than the 7.3 pump. At least the filter is replaceable on the 6.0 pump.
Old Jul 12, 2023 | 10:10 AM
Kwikkordead
Why not just replace the one you have? Or at the very least, replace the filter and see how it goes?
Old Jul 12, 2023 | 10:25 AM
Durk978's Avatar
Durk978
Trailering
It’s a first for me also. I haven’t had any issues with it but now it seems to whine a lot more. So I figured replace the pump itself. I could give just replacing the filter a shot first and see how it goes, and then so forth. I’ll keep you posted on it.
Old Jul 12, 2023 | 10:32 AM
Kwikkordead
A noisy fuel pump like that would indicate that the filter is clogged. Hopefully it's all you need. Most of those rotary style pumps last for decades. What kills them is the brushes finally wear out and they stop turning. They don't give a lot of warning, either. One day they work, the next day they don't. Sometimes banging on the fuel pump while someone else is cranking on the starter will bump it to life, but that's only good for a short while. That goes for just about every make and model of vehicle that runs with an electric rotary type fuel pump.
Old Jul 12, 2023 | 10:33 AM
Kwikkordead
What you have mounted on the frame is an improvement, IMO, to what Ford put there in the first place. I would try and keep it the way it is because you have that replaceable fuel filter.
Old Jul 12, 2023 | 10:55 AM
z31freakify's Avatar
z31freakify
There is a member in the OBS 7.3 side that has the same set up. Just keep it, if its working fine.
Old Jul 12, 2023 | 11:39 AM
Durk978's Avatar
Durk978
Trailering
Is it just a regular fuel filter for a 7.3 tho. Cause the 6.0 has two filters
Old Jul 12, 2023 | 04:55 PM
z31freakify
Do you still have the factory fuel filter/ fuel bowl up top?
6.0 filter micron rating
Primary- 10 micron
Secondary- 2 micron
7.3 filter micron rating
7 micron.
Check fuel pressure if in doubt.
Old Jul 13, 2023 | 05:29 AM
Durk978's Avatar
Durk978
Trailering
I do not have the stock fuel bowl up top, on side frame rail. It’s 6.0 pump/filter with a e fuel set up with a regulated return. That’s what my friend has told me when I sent a video to him
Old Jul 13, 2023 | 05:36 AM
FinnishStroker's Avatar
FinnishStroker
I was not aware of this 6.0 fuel pump that has a filter in it.
I might have used it when i deleted my stock fuel bowl..
Old Jul 13, 2023 | 06:19 AM
Durk978's Avatar
Durk978
Trailering
Pump has filter inside of. The other one is in the fuel bowl In valley which is the small one. Correct? I’ll swap those out either today or tmrw, if that what I gotta do.
Old Jul 13, 2023 | 07:25 AM
Kwikkordead
Yes, start with new filters if all you have is a noisy pump.
jimzpsd
Mar 13, 2020 01:51 PM
AWB2010
Mar 14, 2010 01:23 AM
DAI532
27
Sep 24, 2009 08:34 PM
Big Brew
Jul 18, 2009 10:37 PM
jonjayjabroni
Aug 13, 2005 03:44 PM
