Fuel pump lubricant
Old Mar 10, 2020 | 08:23 PM
jimzpsd's Avatar
jimzpsd
Fuel pump lubricant
So what are you guys using for your fuel pump lube? I've been using the Ford brand since the first fill up.
Old Mar 10, 2020 | 08:26 PM
Lamoon78's Avatar
Lamoon78
The fuel pump lube. I must be dumb to this phrase.
Old Mar 10, 2020 | 08:30 PM
dnoel's Avatar
dnoel
I get it. I’ve been using opti-lube for years including my the 7.3 powerstroke I had. Summer formula works in my area.
Old Mar 10, 2020 | 08:49 PM
aboyles's Avatar
aboyles
Optilube XL
Old Mar 10, 2020 | 08:53 PM
aboyles's Avatar
aboyles
If you are running a new diesel of any brand you need a lubricant additive for your fuel. I didn’t use any and my HPFP failed at 150k. Ford diesel mechanic said I needed to use lube. God knows they didn’t use any lube on me when I got the bill. $8k
Old Mar 10, 2020 | 08:57 PM
Lamoon78's Avatar
Lamoon78
I got ya I do use some just never heard it put like that.
Old Mar 10, 2020 | 09:05 PM
Flitastic's Avatar
Flitastic
Optilube XL
i just got my first order of XL and summer formula. Been using the Pm22 but switching to the XL or summer on next fill up.
Old Mar 10, 2020 | 11:16 PM
MachAF's Avatar
MachAF
None. Waste of money. I suggest you read what your owners manual says about using fuel additives and warranty claims.
Old Mar 10, 2020 | 11:38 PM
SARDiverDan's Avatar
SARDiverDan
For those interested, here is the guidance from the owners manual:
Diesel Fuel Additives
It should not be necessary to add any aftermarket additives to your fuel if you use a high quality diesel fuel that conforms to ASTM industry specifications. Aftermarket additives can damage the fuel injector system or engine.
However, most still add some type of additive to increase Cetane levels or provide lubrication. I have used Power Service for decades and have never had any issues and while I know most follow the “latest and greatest”, I will stick with what I have the most experience in using. On a side note, I have read that Power Service Diesel Kleen and Diesel Fuel Supplement both contain demulsifiers and I have also read articles that claim it does not contain demulsifier. Diesel 911 is an emulsifier and should only be used in an emergency. While I have traveled with a bottle of 911 over the years, I have never used it and most likely never will.
Old Mar 10, 2020 | 11:55 PM
ForCal's Avatar
ForCal
Whether an additive is used or not, Ford won't warranty a fuel system failure anyway. They'll blame it on bad fuel.
Old Mar 10, 2020 | 11:58 PM
ForCal's Avatar
ForCal
I was looking at the Opti-Lube XL, I currently dont use any additive but considered that one. Any places better than others to purchase it?
Old Mar 11, 2020 | 12:10 AM
Hockey18's Avatar
Hockey18
I have been using whatever I buy. Tried many different ones with no noticeable difference but will continue to use something for most fill ups. Anybody have any experience with Alliant ultra guard? A friend highly recommends this.
Old Mar 11, 2020 | 05:47 AM
nomad_archer's Avatar
nomad_archer
I us PM-22. The owners manual recommends using a fuel with a cetane rating of 45. Most that are labeled locally to me have a rating of 40, So I use a cetane booster that also adds extra lubrication. That HPFP is an expensive part to fail. I'll do what I can to help prevent it. Water in fuel is something that a cetane booster wont help but the extra lubrication isn't going to hurt anything.
Old Mar 11, 2020 | 06:13 AM
aboyles's Avatar
aboyles
cheapest place I have found it is dieselpowerusa.com
Old Mar 11, 2020 | 06:22 AM
Lamoon78's Avatar
Lamoon78
Ok doesnt say not to and it cant cause Ford has its on crap they want you to buy.
