Please help
Old Jul 9, 2023 | 05:46 PM
TPatterson00's Avatar
TPatterson00
2nd Gear
Please help
Hey y’all I own a 96 f250 with the 7.3 when I start it, it lopes and it doesn’t matter if it’s in park or neutral if it sits more than a week it looses all fuel prime and if it at 1800 to 2000 rpm it has a mist/ shake I’ve replaced fuel bowl and pump
Old Jul 9, 2023 | 06:50 PM
Beechkid's Avatar
Beechkid
Codes?.............
Old Jul 10, 2023 | 04:29 AM
97-psd's Avatar
97-psd
Sounds like injector orings. How does the fuel filter look? Have you checked fuel pressure at idle?
Old Jul 10, 2023 | 02:26 PM
knottyrope's Avatar
knottyrope
two fuel lines off the frame near steering pump have couplers and orings that can leak
Old Jul 20, 2023 | 10:52 PM
TPatterson00
2nd Gear
No check engine light I changed the fuel pump fuel filter and bowl because it would idle “okay” after I got the lope to stop. But once I would drive it up and down the driveway it would act like no fuel and if it sits more than two days it looses fuel prime and I just want to say thank you to y’all this is my first diesel and I think I bit off more than I could chew
Old Jul 21, 2023 | 09:20 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
OK, but does it have any codes stored? Not all codes turn on the check engine light.
Old Jul 21, 2023 | 10:25 AM
knottyrope's Avatar
knottyrope
what is fuel pressure?
does oil pressure come up fast after sitting?
how many miles since last oil change?
is engine oil level ok? if low HPOP will get air and make for long starts
Aaron Barton
29
Jan 1, 2022 01:16 AM
mrjefferson75
Apr 15, 2011 01:44 PM
jmitchell1982
Jul 15, 2009 04:24 PM
damnedin82
Apr 27, 2008 10:20 AM
