2000 7.3 Diesl Won't Start - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-15-2011, 11:57 AM
mrjefferson75
mrjefferson75 is offline
mrjefferson75 is starting off with a positive reputation.
Hi Guys
I have a 2000 F350 7.3 Diesel. I was driving yesterday when i started to loose power and then the truck just shut off. Here's a list of stuff i have checked. The fuel pump is not turning on and pumping fuel. I swapped the pump and still not pumping fuel. for some reason i'm not getting power to the fuel pump, but cant figure out why
1. I have checked all the fuses and fuel pump relay.
2. I have checked the fuel shut off switch.
3. I have checked the fuel pump and swapped it out with a new one.
Any ideas would be greatly appreciated
Old 04-15-2011, 12:43 PM
jh818's Avatar
jh818
jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
Did you change the fuel filter?
Is the pump getting power? Nevermind...just reread your post.
How about your ignition switch on the steering column?
Old 04-15-2011, 12:56 PM
mrjefferson75
Yes i put new fuel filter and also filled it with fuel
Old 04-15-2011, 01:12 PM
jh818's Avatar
jh818
jh818 is offline
Ground wires on the pump good?
Old 04-15-2011, 01:22 PM
tdpower's Avatar
tdpower
tdpower is offline
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
Make sure your wait to start light is coming on. If not the fuel bowl heater probably shorted out causing a fuse to blow. Should be fuse #30 in the cab.
Old 04-15-2011, 01:31 PM
mrjefferson75
All lights come on dash as they should when key is in on position.
I cant figure out why the fuel pump is getting no power.
Old 04-15-2011, 01:44 PM
fz1dave's Avatar
fz1dave
fz1dave is offline
Super Duty
fz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud of
Maybe one of the mods can move this to the 7.3 forum. You might get help faster in there.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
