Column Shift lever removal
Old Jul 8, 2023 | 01:04 PM
F2502011's Avatar
F2502011
71 F100 automatic steering column. I want to replace the shift lever grommet that goes around the base of the lever where it goes into the collar. Looks like it has some kind of pin that goes through it holding the lever and grommet to the collar. How should I try to remove this?
Old Jul 8, 2023 | 02:23 PM
Green72F250's Avatar
Green72F250
There is a pin that holds the column shift lever in place, find the correct size flat end punch, and hammer and drive the pin thru.
Old Jul 8, 2023 | 02:35 PM
F2502011's Avatar
F2502011
Hammer from the top bottom or doesn’t matter
Old Jul 8, 2023 | 07:06 PM
Green72F250
I don't think it makes any difference which way you tap it out, the tool you use is a flat pointed round punch. The pin is a round hole pin it is #19 in this LMC illustration.
Old Mar 25, 2025 | 10:15 AM
RGDavis's Avatar
RGDavis
4th Gear
Posted to the wrong thread
GeneGregory
Mar 6, 2022 08:28 AM
spongecop
Sep 29, 2011 05:29 PM
Customcab
Nov 16, 2007 10:13 PM
TimRob
1983 - 2012 Ranger & B-Series
Aug 18, 2005 08:02 PM
