Engine Surge
Old Jul 6, 2023 | 08:28 PM
mitch1227's Avatar
mitch1227
4wd Low
Engine Surge
After my truck warms up, my engine will surge for a second then idle down. It does this consistently once the engine is warm. I cleaned the IAC valve and throttle body. I read somewhere that there was an issue with some gasket deteriorating and getting stuck causing blockage somewhere, resulting in idle issues. Any idea on what part that was? I want to say it was the mass airflow sensor? Thanks.
Old Jul 7, 2023 | 08:11 AM
jas88's Avatar
jas88
You need to tell us what engine/trans you have and what year is your truck.
Old Jul 7, 2023 | 11:41 AM
mitch1227's Avatar
mitch1227
4wd Low
Sorry. 1990 F150 4.9 manual transmission.
Old Jul 7, 2023 | 11:46 AM
Prototypemech's Avatar
Prototypemech
Alot of surging idle complaints are caused by vacuum leaks. These trucks are over 30 years old and the vacuum hoses crack like pretzels. Take a good look at all your vacuum hoses. Spray brake cleaner around your intake manifold while the engine is running and listen for changes in the rpm.
Old Jul 7, 2023 | 05:04 PM
My4Fordtrucks's Avatar
My4Fordtrucks
There is no gasket between the air box lid and the MAF sensor to get stuck. Not only that but your ‘90 does not have a mass air sensor.
Jlckb5
Nov 5, 2011 07:25 PM
whitsitt3
Dec 31, 2010 04:57 PM
94fordtruck
Jan 6, 2006 10:26 AM
AllFords1022
Feb 22, 2004 06:38 PM
spider42
Jan 24, 2003 12:54 PM
