Took my new 2022 f150 5 litre into the ford dealer for its first oil change.(5k miles) The 5.0 engine calls for 5w30 oil.The dealer put 5w20 in it.This is my 12th F150,and the first time I didn,t do my own oil change.(getting old).Should I go back and bitch or do you really think it will matter?
How do you know it's 5-20, the receipt? Maybe the genius tech thought he was looking at a V6? Was there a spec change?
Probably not a big deal, but it's their specs, and I would take it back and make them put in the correct oil per their own specs. Then tell them that they should pay attention to the work they perform. What's next, wrong plugs? Wrong Filters? Wrong tire size?
Yes, take it back and make them change it again at their expense.
My stepson has a 2017 5.0L truck. He always has the dealer do the oil change and they always fill it to just 8 qts. I've explained to him that the dealer is underfilling the crankcase by .8 of a quart.
I'd want the oil that is spec'd for the engine for sure. Before going back to the dealer I'd check two things...park the truck on level ground and check the oil level, and also see if the owner's manual says 5w20 is okay. Many engines have a range of acceptable oil viscosities depending on the ambient temps.
The reason why, at 71, I still do my own oil changes. I get the "getting old" though.
