New shock absorbers question
Old Jun 29, 2023 | 02:40 PM
RollingPOS's Avatar
RollingPOS
73 250 camper special. I am needing new shocks. When I checked Rock Auto it was hard to tell which would work best. Some said "not for camper special".also it looked like coil spring struts were available. Is that an upgrade? I am wanting to haul a pretty heavy street bike on trailor hitch. And have some gravel roads that are a serious washboard situation ahead of me this summer.
Old Jun 29, 2023 | 09:30 PM
1browski's Avatar
1browski
I used the Monroe 34900 on the front and 34911 on the rear of my 70 f250 camper special. It does say not for the camper special for the 34911 but that is the one that fits on my truck. On the Rockauto site, just click on the picture and see if it matches yours. I dont know which others will fit but those are the only ones I have used before.
Old Jun 30, 2023 | 09:37 AM
beartracks's Avatar
beartracks
Monroe gas magnums
Old Jun 30, 2023 | 01:15 PM
tbear853's Avatar
tbear853
Originally Posted by beartracks
Monroe gas magnums
Hard to beat them.
Any running F-250 should haul any bike no problems, or pull any "bike trailer" designed just to haul bikes ... no need for coil over helpers.
Old Jun 30, 2023 | 01:28 PM
ivsamhain's Avatar
ivsamhain
Whichever oil shocks I can find do it for me.
Old Jul 2, 2023 | 11:47 AM
FuzzFace2's Avatar
FuzzFace2
Originally Posted by tbear853
Hard to beat them.
X2
And you DO NOT want to use shock mounts to support any weight as they were not made to do so.
Just because coil over shocks are made dose not mean they are right!
That also goes for air shocks if they are still made.
Dave ----
Old Jan 16, 2024 | 09:57 PM
TheGreatPumpkin's Avatar
TheGreatPumpkin
So should I stick with the 5100s then? Thats all I've ever replaced shocks with but I have been curious about the Foxs, probably not worth the hassle to try and make coilovers work. I doubt I would notice the difference I'm not planning on haulin or off roading. The only advantage I can see is the rebuild factor on the foxes but I'm sure there are downsides to that and probably won't save me much. Realistically if I made it to the point of "A" rebuild how much would I truly save in time and money?
Wizards, your thoughts?
Old Jul 24, 2024 | 03:00 PM
TheGreatPumpkin
Has anyone here done the any Bilstein's on a lowboy? I'm having trouble find the stock specs, what size bilsteins I would need and lift information. My front end needs to get leveled out because the 460 drops it quite a bit. The truck originally came witha 400m in it, not sure how much the 460 would have made it squat and then the how much it has sagged over time factors.
Texas_1969_F250
Feb 3, 2023 11:58 AM
briangregory
Sep 25, 2022 11:30 PM
brk300
Sep 14, 2016 11:42 AM
big red 73
Oct 7, 2010 01:20 PM
1990Fordf150v8
Sep 19, 2003 03:29 PM
