Rear Shock part number question
Old Sep 13, 2016 | 06:45 PM
brk300's Avatar
brk300
I have a 78 SC 2wd Camper Special that I need to replace the rear shocks on. Everywhere I look for shocks the its the same thing they all say "w/o Camper Special" for every shock listed. Are they really different? I will not be towing or hauling anything remotely heavy can I just go with the standard Monroe rear shock #34911 or am I missing something?
I ordered and installed the yellow Monroe gas-magnum shocks #34900 up front and would like to match the rear if possible.
Thanks
Old Sep 13, 2016 | 06:59 PM
HIO Silver's Avatar
HIO Silver
Just to dovetail, does anyone know for a fact why CS-spec trucks are the exception?
Old Sep 13, 2016 | 07:13 PM
rougeriver's Avatar
rougeriver
I would think that it's because those trucks were set up with heavy-duty leaf springs and shocks to accommodate the added weight of a slide-in camper, and that special exception is listed to preserve that capability. Since you don't care about that aspect, put what you want on.
David
brk300's Avatar
brk300
I had ordered the MONROE 34958 shock (without actually looking at my setup) as it was the only one that said "Rear; RWD; Crew Cab Pickup; w/ Camper Special" but I found out the hard way the crew cab uses bushing mounts on the top of the shock where the SC Camper Special uses the Stem mount.
It can never be easy can it
Old Sep 14, 2016 | 12:45 AM
Ozzie H.'s Avatar
Ozzie H.
What's an SC?
Old Sep 14, 2016 | 12:50 AM
HIO Silver's Avatar
HIO Silver
Originally Posted by Ozzie H.
What's an SC?
SuperCab.
Old Sep 14, 2016 | 10:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Two pics of 18125 rear shock applications:
Old Sep 14, 2016 | 11:42 AM
brk300's Avatar
brk300
Thanks for the info Bill. I still cant find the correct shock application though..
1978 Supercab 2wd w/Camper Special
Unless the CS option did not change the shocks used from the standard F250 package.
jasonious
Jul 29, 2012 11:11 PM
LeeShuster
Oct 8, 2010 02:39 PM
big red 73
Oct 7, 2010 01:20 PM
baugh009
Jun 27, 2007 01:30 PM
