2010 Ranger 2.3 / auto shift problems
Old Jun 27, 2023 | 09:26 AM
ironrook's Avatar
ironrook
3rd Gear
Here is whats going on.
2010 Ford Ranger 2wd 2.3 motor 184,000 miles
From starting the truck I cannot move in D or R, but if I put it into drive D1 or drive D2 then I can use R.
Cannot take off in D.
I drive it by starting in D1 or D2 then shifting up to D.
All this works better with overdrive turned off.
Replaced fluid and filter. No metal flakes.
I replaced the output shaft speed sensor and unplugged the negative battery terminal for an hour today because that's the code I had seen.
Still doing the same thing .
Any help is much appreciated.
Old Jun 27, 2023 | 03:31 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You've described what happens when the overdrive one way clutch fails. The trans needs to come out and get at least partially torn down to replace this.
Old Jun 27, 2023 | 04:59 PM
ironrook's Avatar
ironrook
3rd Gear
Any idea on cost and if I go that far should I just get a full rebuild?
Old Jun 27, 2023 | 05:27 PM
Mark Kovalsky
If it were mine I would go with a full rebuild. I am very out of touch with current prices.
daniel5625
Jan 21, 2011 05:25 PM
mattmtx1
Oct 31, 2009 04:37 PM
bnix
Mar 10, 2004 07:00 AM
