LED cluster swap
Old Jul 10, 2023 | 05:43 PM
scottscott's Avatar
scottscott
Might be location 7. Check for voltage at that location with the key on.
Old Jul 10, 2023 | 05:47 PM
Tmd_87's Avatar
Tmd_87
nope not getting close to 12 V anywhere with key on.
Edit- okay only getting 12+ V at 10 and 11 key on
Old Jul 11, 2023 | 04:54 PM
scottscott's Avatar
scottscott
Pop the PC connector off of the IVR. Follow the traces on the PC that run from the IVR connectors. One should run to the studs for the gauges, the other trace should run to the socket. Which location does the trace that runs to the socket go to on the harness plug? I'm guessing it is #7. I don't have a 74 cluster at the moment, so I am guessing here.
Whatever the location is, it should have power with the key on. If it doesn't you have to figure out why it doesn't have power. I don't have a 74 cluster, wiring diagrams, or owner's manual at the moment, so I'm not going to be much use tracking down where the power comes from.
outdoorfan
May 12, 2011 06:14 PM
SG1NUT
Sep 12, 2008 11:03 AM
hush210
1997 - 2003 F150
Feb 23, 2007 08:37 PM
truchafuego
Feb 25, 2005 05:07 AM
Phobia16V
Nov 16, 2003 10:41 AM
