Midship fuel tank help
Hi everyone. Thanks in advance for any help. Pardon my bumpside, but underneath the cab and bed is a 1977 F250 with a 460/C6 auto. I bought the truck in an early/mid project state- the in cab tank was removed, there is no tank behind rear axle, and there was a rusted midship tank from a 1989 f150 held up by makeshift straps and 10mm self taps.
The existing tank was too far gone to salvage so I removed it. I ordered a tank from LMC truck (43-5016). It didn’t fit. The 22.5gal tank was for the 1972 and was too tall. I then got a spectra f6C from auto zone, because it was basically the same as the rusted out f150 donor, but I couldn’t find a non fuel injected sending unit! I bought the manuals and parts list CD and found out the OEM parts were a plastic tank with a sheet metal cradle. The latter is a unicorn and not a realistic immediate solution. I will eventually get a rear tank, but I’d like to get on the road and remove the 1gal tank bunjee corded in the engine bay. Can anybody help me find a readily available and viable midship tank solution?
The following users liked this post:
So a 4wd 1977 (late made NONE High boy) will/should have a OEM plastic side tank, held up by the metal cradle/skid plate. A repop poly side tank and sending unit can be found, the cradle not so much. Time to get crafty with some metal and a welder and build a cradle that bolts on. A 2wd truck will have a metal side tank held up by 2 straps.
Poly side tank: https://raybuck.com/product/1973-197...E&gclsrc=aw.ds
JGT (Just gas tanks poly: https://www.justgastanks.com/1973-19...kup-fuel-tank/
GTD (Gas tank depot) poly: https://www.gastankdepot.com/4249-pl...19-gallon.html
NO rear gas flap so this rear one will not work, unless you are ready to make/add a gas flap. https://www.tanksinc.com/index.cfm/p...rod/prd176.htm
Fill necks:https://www.tanksinc.com/index.cfm/p...cat/cat166.htm
Sending units ect...
Parts Vendors & Resources
Dennis Carpenter Ford Restoration Parts
National Parts Depot:Ford Truck Parts & Accessories | 1948-1979
MAC's Antique Auto Parts
Blue Oval Truck Parts
Jeff's Bronco Graveyard
The Early Ford Store-San Dimas,CA
Truck & Car Shop (Orange, CA): 48-86 Ford Trucks, 66-86 Ford Bronco
C&G Early Ford Parts: 32-79 Ford Trucks (Escondido,CA)
Sacramento Vintage Ford
Flashback F-100s: 48-2008 Ford Truck Parts
Vintage Pickup Truck Parts & Restoration Resources Directory
Green Sales Company - Vintage NOS & OEM Parts
LMC Truck - Ford Truck Parts and Truck Accessories
@77&79F250
That is a nice list of supplier links you posted.
@Caseydooley
Food for thought here:
I put my '77 F250 2wd cab onto a '77 F350 2wd chassis. Both were CrewCab pickups and the cab donor was a short-box.
My pickup is now a '77 F350 longbox CrewCab pickup with in-cab fuel tank, and a steel belly tank from the shortbox F250.
I modified the mid-ship belly tank frame hangers to be moved rearward to accomodate the added length of a NP205 transfer case.
Don't Forget: - the mid-ship belly tank brackets have a safety strap which goes around the front of the tank, so it doesn't become a torpedo in a head-on crash.
Fillernecksupply.com is another good source of fuel system components like the grommet for the roll-over-valve.
I wound up putting a '77 longbed box on my pickup which has two filler doors. The front filler door is used for the belly tank.
To get fuel from the filler door to my belly tank inlet, I simply used two exhaust pipe pre-bent elbows, cut and welded together to make an "S" bend, allowing straight run pieces of hose from filler-inlet to tank-inlet. Bing-bada-boom.
Remember liquid is approx 8-lbs per gallon so if using a 19-gallon belly tank a full tank will weigh approx 150-lbs, so make sure your mounting hardware is up to snuff for the weight the brackets are carrying.
Typically I like using an existing oem bracket or part, and then modifying to my spec and needs. I just figure the factory pieces are up-to-the-task.
That is a fine looking F250.
I almost purchased a '72 pre-smog F250 4x4 a couple years back, and passed just because I don't have the time to devote to a complete do-over.
The highboy's with the divorced transfer cases are very cool pickups.
@Caseydooley
79super460
16
07-05-2012 04:01 PM
