Engine questions
Old Jun 20, 2023 | 12:21 PM
Phenixgarage's Avatar
Phenixgarage
Engine questions
So I have a 1978 f150 with the 6.6 ltr v8 400 and was wondering if it is an interference engine or a non interference engine. Also looking for a good vacuum diagram. And for the factory snorkel thing
Old Jun 20, 2023 | 01:44 PM
Michael.b's Avatar
Michael.b
4wd Low
Old Jun 20, 2023 | 01:58 PM
beartracks's Avatar
beartracks
Not interference.
Old Jun 20, 2023 | 09:59 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
A 1978 400 is a non interference engine.
A few more vacuum diagrams https://www.ford-trucks.com/forums/1...l#post20821317
"Factory snorkel" you mean assembly #9A624? The plastic piece that connects to the back side of the radiator core support and the black flex pipe? The hard plastic piece is not reproduced AFAIK. I know a guy that has one. https://www.ford-trucks.com/forums/forum238/ PM me.
https://www.testingautos.com/car_car...ce-engine.html
Old Jun 21, 2023 | 02:33 PM
ranger140892's Avatar
ranger140892
Grumpy goat
I've heard "interference engine" used different ways. For my clarification, what are we calling an interference engine here? My understanding of it is, that an non-interference engine cannot have valve to piston contact, in the event of a cam timing failure.
Old Jun 22, 2023 | 01:02 PM
Greaser007's Avatar
Greaser007
Personally, I've had great luck with the 400M engines.
I ran one for over a year with a rod-knock. When purchased with supposed bad tranny, the pickup came with a rod-knock. hahaha _ _ go figure, right.
In the time I ran it, I purchased a used (supposed rebuilt) engine which was not, so I freshened it up with a "Greaser-refurb" and switched engines.
Was in a '76 F250 Crew Cab, and had a Fed-Ex driver follow me to a stop and asked if he could buy it. I sold it to him 2-months later.
I ran into him several years later and he loves the pickup, so the 400 was running strong.
Old Jun 22, 2023 | 01:55 PM
77 HOS's Avatar
77 HOS
Or in the event of mechanical over rev causing contact between the two because the valve spring cannot close the valve quick enough to miss the piston. Valve float
Old Jun 22, 2023 | 02:07 PM
beartracks's Avatar
beartracks
Interference means that if the chain or belt driving the cam breaks leaving a valve fully open it can hit the piston.You would have to have a very big cam and or compression ratio on a 400.
Old Jun 22, 2023 | 02:30 PM
ranger140892
Grumpy goat
Right. By that definition, a 400 is an interference engine. I had a stock 351M bend valves after the nylon gear teeth sheared off the camshaft gear. Yes, the 400 has shorter compression height pistons, but that only makes a .047" difference in deck clearance. Not enough to prevent piston to valve contact.
79shortbed
May 21, 2013 03:50 PM
berry1234
Mar 27, 2010 10:24 AM
