I found that #10 had blown before I owned it. That plug is epoxied in place. I think it was #4 and #2 that blew earlier. I know that there is a non-stock program in the PCM. It never turns the CEL on when there is a problem. And I know of a few minor problems that should turn the light on, such as a misfire problem.
It is a 2 valve. I meant a later 2 valve. As I recall, and I wasn't directly involved, the thread problem in the heads was fixed by 2002. The two valve ran at least through 2005 in the E-Series. There are a few available, but they are asking more for them than the reman companies are asking for their engines. And I don't think the truck is worth putting that much money into it.
I am looking for another Excursion, but it will have to be either a 7.3L or a 2002 - 2005. Or I would take an F-250 or F-350 SRW that does not have either a 6.0L or a 6.4L. I'm not into that type of disaster.
How is the condition of the excursion, other than the engine problems? In Florida? Could look for a good used v10 and swap. If the truck were close to me, I'd fix it for you just for the conversation.
pull the electrical connector on that cylinder and you can at least keep driving it, 9 is still more than 8
The truck is pretty clean. It spent the first part of its existence in Montana, so it was not always in Florida.
A reman engine is $4500, plus the labor to install it. I could do it, but I won't. Labor has been quoted at $3000. A good used engine is about $300 MORE than the reman.
I'm going to sell it for whatever I get for it, probably to a scrap yard.
No rust? I'd be interested in coming to get it if it's clean
Seems like a good candidate for a Cummins swap. A decent Cummins swap can be done at home in the $7K-ish range depending on what else you decide to do "while you're in there". More expensive that just swapping in a new V10 for sure, but you end up with something that tows better, gets way better fuel mileage, in very reliable and lasts a lot longer. With the only real downside being you can't just drop it off at any old repair shop anymore, you have to find a specialty diesel shop if you want to have work done on it vice doing it yourself (not an issue for me as I do all my own work anyway.
I bought the newest SUV I could that was capable of towing a decent size RV, unfortunately that was/ is a 2005 Excursion.
If there was a more modern equivalent offering, I probably would've gone that route, but there just isn't. But as it sits now with the 12 valve Cummins and five speed manual transmission, my 05 Excursion is just about the perfect vehicle for what I want it to do and that's haul my entire family (including the dogs) in air conditioned comfort, while towing a 34 foot travel trailer through parts of the country where the closest civilization is hours away and not worry too much about it breaking down (that last part is why the 6.0 had to go).
I won't even look at a vehicle with a 6.0L, or even worse, a 6.4L.
After having owned both 6.0 and 6.4 powered vehicles (well, technically still own two of them, both just have Cummins engines in them now) , I 100% concur with avoiding the 6.0, and the even worse 6.4. Great trucks other than the crap-tastic engines they were unfortunately saddled with.
