7.3 gearing question
Old Jun 16, 2023 | 10:38 AM
RandyinTN's Avatar
RandyinTN
10 speed transmission owners, 3:73 vs 4:30's. What is your trucks rpms at 70 mph?
Old Jun 16, 2023 | 11:05 AM
GAZZILLA's Avatar
GAZZILLA
F250 4x4 7.3 4.30 295/70/18 34.5’s here, at 70 mph it’s turning 1900 rpm’s at 65 mph it’s turning 1700 rpm’s. With my setup it has no problem towing my 5k lbs TT in 10th. I would like to go to 315/70/18 35.7’s to bring the rpm’s down at bit more.
Old Jun 16, 2023 | 11:32 AM
ArtCO's Avatar
ArtCO
I have a stock XLT 7.3/3.73 with 18" wheels/tires. 70 mph is approximately 1700 rpm and 80 mph is approximately 1900 rpm.
Old Jun 16, 2023 | 12:52 PM
BSHORT's Avatar
BSHORT
Top Answer: 5
Stock AT tires with 4.30, I recall 2K at 70 in 10th.
Old Jun 16, 2023 | 07:37 PM
scraprat's Avatar
scraprat
Top Answer: 5
3.73 gears, 275/70r18 tires
Old Jun 16, 2023 | 07:41 PM
Vipersgts1's Avatar
Vipersgts1
23' F250 3.73
275/70r18 (32" actual size) 1650rpm@70mph
new tires:
37x12.50r18 (35.75" actual size) 1550@70pmh
Old Jun 16, 2023 | 08:26 PM
acadianbob's Avatar
acadianbob
4.30's are basically 2K RPM @ 70 mph with stock tires.
Old Jun 16, 2023 | 09:08 PM
bigwin56f100's Avatar
bigwin56f100
that looks about right for my 3.55 gears with the stock tires 18" wheels. Thankfully I didn't get 4.30 gears. 2000 Rpms at 70 mph? And who does the speed limit? 75-80 mph would be horrible
Old Jun 17, 2023 | 06:01 AM
last5oh_302's Avatar
last5oh_302
Love towing a 13 plus ft tall, 14k toyhauler on cruise in 10th with 4.30's and no tranny hunting. DRW tires are 31" so 2000 rpm at 70. I'd buy the same set up again. It tows like the beast it is and I can still go 80 or more if I want. At 80 or more it doesn't matter what gear you have at this point. You'll be drinking the gas.
Old Jun 17, 2023 | 08:24 AM
RandyinTN's Avatar
RandyinTN
Thank you all.
Old Jun 17, 2023 | 03:03 PM
twobelugas's Avatar
twobelugas
Not in my experience, it does matter at that speed. The 3.xx will have the 9th and 10th that can comfortably cruise around 2k rpm at that speed while the 4.30 will be approaching 3000rpm unless the torque converter is fully locked. The 3.xx won't be winning any MPG contests but it is a lot more relaxed than 4.30 at higher speeds.
Old Jun 17, 2023 | 04:15 PM
last5oh_302
The wind resistance against an 8000lb brick is also a factor.
While towing fairly heavy I do enjoy that the 4.30 gear allows setting the cruise at 65 mph at 1900 rpm while holding 10th, unless there's a strong head wind in which case it will usually hold 8th or 9th.
Old Jun 17, 2023 | 04:53 PM
twobelugas's Avatar
twobelugas
Well then you should stick to the right lane with your 4.30, as long as you are not impeding traffic you do you.
Old Jun 17, 2023 | 04:58 PM
last5oh_302
Of course.
Old Jun 17, 2023 | 05:48 PM
BSHORT's Avatar
BSHORT
Top Answer: 5
Relaxed? Geez. I take it no one ever towed anything with an old 350 3 speed truck at highway speeds.......
